Weird squeak
Old Apr 23, 2011 | 12:26 AM
wiggins82abn's Avatar
wiggins82abn
Default Weird squeak
Ok, I am going to try and describe the noise I am hearing... When I accelerate, (only at 1/3 throttle and greater) I hear a high pitch squeak coming from the front of the engine compartment. It goes away after a few seconds. It happens again when the gears change, but only when it changes to second, and not third and fourth. When I lightly accelerate it does not happen at all. Also, if I am cruising at anywhere between 20 and 30 and goose the thottle, it does it again for only a second.
Should I be worried about a pulley problem or is it just the belt showing its first signs of needing to be replaced.
(2005 vert A4)
Old Apr 23, 2011 | 12:36 AM
Rossi6998's Avatar
Rossi6998
Although it is a guess, I would start with the belt...
Good luck!
