Strange Charging Problem
Old Apr 25, 2011 | 04:17 PM
csnow's Avatar
csnow
Stater wires appeared to be loose but on further inspection it looks like the whole soleinoid is moving at the stud. Not sure what could be causing the movement unless whatever is holding the soleinoid to the body of the starter is loose. I cant see in there and my hands barely fit between the header. It not moving much but I can see it give with the wrench on the nut.
I will lift it this weekend and get a better look from beneath. Will the starter squeeze out with LG headers? Or do I have to drop the header to get it out?
Cables passed the voltage drop test.
Old Apr 25, 2011 | 04:51 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You certainly do not want that starter moving. It can break your block. Someone here will know what the starter bolt torques are.
Old Apr 25, 2011 | 09:55 PM
csnow's Avatar
csnow
The starter itself isnt moving, it is the solenoid that appears to have some play in it. Primarily the main stud that takes the postive cable.
Old Apr 25, 2011 | 10:12 PM
bolivar's Avatar
bolivar
I think you've found your problem.
Somewhere in its life before being firmly bolted down, that stud took a whack.
Old Apr 26, 2011 | 07:58 AM
dgrant3830's Avatar
dgrant3830
I agree...doesn't sound like it should be moving. Now this alone won't cause a charging problem but if the main cables to it were lose, now you have a cause.
