Front end alignment
You don't NEED to know anything technical as long as you trust the alignment tech and can communicate what you want.
My Z06 was set for performance handling from Bowling Green(actually aligned very good) but I wanted more tire life, and since I don't track my car, being able to pull 1.05 G in the school parking lot, was not important to me.
See http://www.pfadtracing.com/blog/wp-c...-alignment.pdf
I had my alignment set about middle ways of "Performance Street" and "Performance Street-Track Use with Street Tires", but with as close to 0.0 degrees toe, front and rear. Absolutely with no toe out.
Go to a shop that will put the numbers "on the money" rather than just close. It will cost you a bit more, but I think you'll get much better results.
- Mark
Took mine to a shop that also does race cars and had the latest Hunter machine. Told them what I wanted...and it was perfect...but -- with a warning "do not drive over 125 with this alignment".
If the toe is off, you'll cup the tires.
If the camber is off you'll wear the inside/outside edge but not with cupping.
Caster doesn't really kill the tires that I know of.
So, set the toe to 0 on all 4 wheels (+/- 0.0)
Set the camber to 0 on all 4 wheels (+/- 0.0)
Set the caster to stock.
What do you use negative camber for? Think about it.... You want the tires to present a flat foot print on turns, yes? No? When they want to go really fast in the turns, the camber is set to a higher negative number, yes, No?
I suggest "yes" to those 2 questions. So, what does negative camber do to a tire that is running straight down a superhighway? Think on it a sec.... It ***** the wheel to put more pressure on the inside edge of the tire. Where is the "bad" wear the horror stories have complained about? The inside edge of the tire is "down to the belts" and the rest of the tire is great. Sound familiar?
Yeah, yeah, 0 camber is horrible!!!
Think about this... A solid rear axle has how much camber? I'm thinking 0. Does a solid rear axle wear out the inside edge of the tires? I'm thinking, no.
So, in conclusion and before I put on my asbestos suit, I will set my toe to 0, my camber to 0, and the caster to the stock number. I'll continue down life's superhighways in ignorant bliss with the top down and a smile on my face.
When I go racing, pylon crushing, or X-Cross, then I'll crank in the negative camber, -2.0 or whatever, and go for it!
Here's the "stock" settings for our cars. It says 2007 but it applies to all of the C6s
Elmer
Elmer
Toe-out, however, will wear the inner edges in a hurry and also tends to make the car twitchy.
I use 0 toe front & rear, .5 negative camber front & rear. Works well for me.
