Interior Lights Issue, Please Help...
Old Apr 30, 2011 | 04:33 PM
DASHZNT's Avatar
DASHZNT
Default Interior Lights Issue, Please Help...
I have a 2006 C6 Vert, my interior lighting does not turn on at all. The lights under the mirror and also on the floor, vanity mirrors and the home link doesn't work (won't even light up)... I cannot figure out how and why this is happening, I've read the owners manual and forums and google with no help. Does anyone know how to fix this, is this common or am I the lucky one?!!
Thank You.
Old Apr 30, 2011 | 04:44 PM
Z11409's Avatar
Z11409
check both fuse box locations
Old Apr 30, 2011 | 04:46 PM
DASHZNT's Avatar
DASHZNT
I did, there is no fuse that properly corresponds to that issue.. I read the owners manual and shows what each fuse does, but not one says anything about interior lighting or dome lighting... Hence, why I'm kind of stuck at thus point.
Old Apr 30, 2011 | 05:13 PM
DASHZNT's Avatar
DASHZNT
Does anyone know something I don't?
Old Apr 30, 2011 | 05:19 PM
Rocketmanwpb's Avatar
Rocketmanwpb
My owner's manuel (2008) indicates there is a courtesy light fuse in the driver's compartment fuse box
Old Apr 30, 2011 | 07:44 PM
DASHZNT's Avatar
DASHZNT
I fixed it, you were correct It was a fuse and it was that one... I just decided to pull every fuse and check each one to make sure nothing was blown, I found one and swapped it out and everything works fine... Thank You.
I LOVE these forums, they are so helpful and there is always someone online, ready and willing to contribute what little or vast knowledge they may know... Thank You.
Old May 2, 2011 | 04:06 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
You should check with the dealership? The dealer may be able to narrow down why the interior lights are not working. It could be something with wiring too. I am not as technical as most of the guys out here. I just thought I would try to help.
Brent
GM Customer Service
Old May 2, 2011 | 04:08 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
Brent
GM Customer Service
To Interior Lights Issue, Please Help...
