Check with the dealership to see if they will replace the battery separate from your vehicle. Some of the dealers want you to bring the whole care, yes to flatbed the Corvette in its entirety, just to replace a battery. Others will take the battery from your hands, and replace it.
Keep in mind, just because a battery tests well does not always mean it is a good battery, as I am sure many have seen on the forum.
I just replaced a 6 week old AC Delco battery. It had the most bizzare symptoms but refused to crank even when jumped. replaced battery and fired right up. It had sat 7 days from the last drive.
Dealer wanted me to flatbed the car to replace under warranty - decided not to. Went ahead and purchased another AC Delco 85-6YR battery (replacement for the discontinued 85H7YR) through the dealer this time for ~$99 total and installed myself - took about 5-10 minutes to install and another couple minutes to reindex the windows. Back in business again! I may take it in later to check current draw, but I doubt that's the problem - I'll just need to drive it longer more often and keep on the Battery Tender if sitting for longer periods. Took it on a 60 mile round-trip tonight.
