Driver window will not index
Old May 2, 2011 | 09:31 PM
ridered494's Avatar
ridered494
Default Driver window will not index
Well battery went dead the other day, and sure enough one window will index and the drivers side will not. I tried the sequences in the book and on the forum search. Out of ideas, anyone have anything for me?
Old May 2, 2011 | 09:32 PM
ub2slow2
Guest
Posts: n/a
Good time to trade it in don't ya think?
Old May 2, 2011 | 09:36 PM
RAGGDOLL's Avatar
RAGGDOLL
Toronto Events Coordinator
When I had this issue, I disconnected the battery and left it disconnected for an hour. Hooked it back up and was good to go.
Old May 2, 2011 | 09:40 PM
ridered494's Avatar
ridered494
I will try that tomorow, and too soon to sell it I just got it couple months back.
Old May 2, 2011 | 09:41 PM
RicK T's Avatar
RicK T
Disconnecting the battery again might help.
If not, try doing the index procedure for both the "up" and "down" positions.
Old May 2, 2011 | 10:11 PM
forg0tmypen's Avatar
forg0tmypen
There's a fix in the owners manual...something like roll the window all the way up then hold the up button for 3 second then repeat...it worked for me...maybe it's 5 seconds can't remember
Old May 2, 2011 | 10:17 PM
cclive's Avatar
cclive
I'll bet you did it with the drivers door open....
Old May 2, 2011 | 10:18 PM
ZROCKET6's Avatar
ZROCKET6
Disconnect Battery then reconnect open window on drivers side first Roll window up Hold 3 second and let it down hold 3 second then roll up Now repeat passenger side same way. You have to reset your DIC settings
Old May 2, 2011 | 10:21 PM
RAGGDOLL's Avatar
RAGGDOLL
He's done that.
For some reason the window has lost it's home location in the upper position. The sensor thinks it's all the way up when in fact it isn't. Disconnecting the battery for a period of time will clear the error in the window module memory and it should revert to normal.
At least that's what has worked for me.
Old May 2, 2011 | 10:26 PM
MARSC6's Avatar
MARSC6
Since I disconnect my battery when not in use this happens to me periodically. Just disconnect the battery for a minute and try again.
Old May 3, 2011 | 08:09 AM
txsugar08's Avatar
txsugar08
I saw a post a few weeks back with the same problem. If you have the "window valet" installed remove it.
Old May 3, 2011 | 03:08 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
You have gotten this already, but disconnecting it does seem to help. Disconnect, and then attempt to re-index again.
Good luck.
Brent
GM Customer Service
Old May 4, 2011 | 09:24 PM
ridered494's Avatar
ridered494
thanks guys. disconnecting the battery worked.
Old May 4, 2011 | 09:40 PM
RAGGDOLL's Avatar
RAGGDOLL
When I first did it, I only disconnected the battery for a minute or so, and then reconnected. Did nothing. Tried it again, this time leaving it disconnected for 45 minutes. That fixed it.
Seems that extended time clears the memory and reverts it to normal "home" settings.
To Driver window will not index
