intermittent starting problem
Old May 5, 2011 | 03:45 PM
Riptide Mike's Avatar
Riptide Mike
Default intermittent starting problem
I have an 06 C6 A6 with 49k miles. The other day I went to start it and there was a clicking sound coming from behind the start button, but no start. The "No Fob Recognized" came up on the screen although it was in my pocket (Batteries were replaced a month ago).
Then about 30 seconds later I tried again and she fired right up. No more issues the rest of the day.
Last night the exact same thing happened. After two tries it started up. Car is out of warranty so if i can fix it myself I would prefer to.
Any ideas? Switch maybe? I am all ears.
Old May 5, 2011 | 03:58 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Sometimes that is caused by RF interference from something in the area.
Or it could be a bad battery in the car (or loose connections).
Old May 5, 2011 | 04:08 PM
rockethead7's Avatar
rockethead7
Mine does this from time to time....
But, I *have* noticed a certain pattern. Whenever I've been parked in this one parking space (well, I don't park there any more, BECAUSE of this), I have a hell of a time getting the door opened, and getting the car started. Same thing "no FOB detected" when I try to start the car, with the standard accessory relay clicking in the dash. This parking spot was near some large mechanical equipment of some kind, with large power lines feeding it. The only thing I could figure is that it was giving off some R/F interference that was cross-talking with the FOB.
Like I said, as soon as I noticed the pattern that it always happened in that one parking space, I stopped parking there.
I have also noticed that on this one stretch of highway that I frequently drive on, in the same exact spot, no matter which car I drive, I lose GPS. (No, it's not because I'm going into a tunnel or anything dumb... I lose satellite reception with clear skies above, almost every time I drive through there.)
Radio is a strange thing. Yes, the FCC is in charge of assigning frequencies for each different type of device, etc. And, theoretically this is supposed to prevent overlap and stuff like that. However, radio is weirder than that. For example, if one frequency is exactly DOUBLE that of another frequency, then it still can cause interference... same goes for exactly TRIPLE, QUADRUPLE, you get my point. Also, radio waves can bounce off of oblong shapes and metal objects on certain angles, and then the wavelength actually is CHANGED as a result. So, even if the FCC assigns a certain frequency, if the signals are bouncing off of things at exactly the right angles, something of a totally different frequency can interfere with your Corvette FOB signals.
Or, yeah, yours could just be broken.
Old May 5, 2011 | 05:15 PM
CO Lightfoot's Avatar
CO Lightfoot
NO FOB DETECTED message can be a symptom of a weak/dying car battery.
If your car battery is the original, then start shopping for a new one. I bet you'll need it soon.
Lots of "what is the best battery" threads, like this:
http://forums.corvetteforum.com/c6-t...post1577004437
Old May 5, 2011 | 06:04 PM
Thrill6's Avatar
Thrill6
If the fob is in my left pocket, never have an issues but with the fob in right pocket, I have about a 20% chance of getting FOB NOT DETECTED. Can also be an issue if the fob is in the same pocket as your cell phone.
Old May 5, 2011 | 06:10 PM
bigterpsfan's Avatar
bigterpsfan
Most likely culprit is that you have your key fob in the same pocket as your cell phone. See if there is a pattern there! Ooops didn't see the post above, but obviously, I concur!
Old May 5, 2011 | 07:06 PM
Riptide Mike
Thanks everyone. I appreciate the info. I normally carry my cell in my left pocket and my keys on the left side as well. Will keep an eye on the battery as well.
Thank you very much!!
Old May 5, 2011 | 07:36 PM
cylon's Avatar
cylon
did you have your cell phone in the same pocket as the fob? kills the broadcast capability of the fob
Old May 6, 2011 | 01:36 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
There are a lot of different reasons that your key fob may or may not be detected. It does use waves to show detection so things like electronics and/or positioning can cause interference.
Did you get this situation worked out? Did you check your car battery?
Brent
GM Customer Service
Old May 6, 2011 | 03:23 PM
cclive's Avatar
cclive
Try fob in right pocket and see...
To intermittent starting problem
