Jump Starting
Old May 7, 2011 | 11:50 AM
Stan0324's Avatar
Stan0324
Default Jump Starting
Thought I would take a look and find the Pos and Neg remote terminals just incase I need to use them (especially in the dark). No problem with the Pos but the Neg ?
If it is that bolt at the very front of the block under a wiring harness and near 2 hoses, wow, couldn't GM have found a easier place to put it ? I haven't tried, but I guess you can squeeze in the jumper cable.
Also, is this the place I should plug in my Ctek ?? Seeing this, I guess the cigarette lighter option must be a great seller.
Old May 7, 2011 | 12:03 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I always jump direct to the battery. Its no problem if you do it right.
Been doing it that way since about 1962, I prefer to use the shortest path for the juice to go over!
Old May 7, 2011 | 12:33 PM
pmzangag's Avatar
pmzangag
For the battery tender I use the first header bolt on the passenger side for the (-). IIRC, the owners manual lists that as one of the remote negative locations. For the (+) I use the remote terminal located under the fuse box door.
Old May 7, 2011 | 01:46 PM
VET4LES's Avatar
VET4LES
You can use any grounded bolt or location that your clamp will attach to.
Old May 7, 2011 | 02:59 PM
Slogo's Avatar
Slogo
I've had to charge/jump mine several times. Best place is always right to battery in my opinion and easy access too.
Old May 7, 2011 | 03:23 PM
MARSC6's Avatar
MARSC6
The one time I had to jump the vette I used the battery post.
To Jump Starting
