buying a new FOB #1
buying a new FOB #1
i have lost my FOB #1 (2008 Z06) and looking to buy a new one. i found different types of FOB #1 , which has confused me.
can anyone tell me the difference between the following:
1. Transmitter, corvette, w/o remote entry lock, fob #1 year: 2008
2. Transmitter, corvette, w/remote entry lock, specific frequency, fob #1 year: 2001
3. Transmitter, corvette, w/remote entry lock, low frequency, fob #1 year: 2008
i am confused which one to buy.
partstaxi has them on the web site.Just put your car info and the right one should pop up.I didn't know there was more then 1 type to get for 08 and up.I NEED ONE TOO!!Same reason.
The only differance between a #1 and #2 is number on the back of the case.
2005 - 2007 early style
I got mine from www.GMPartsDirect.com for $52.02 + ship & handling ($64.97).
#1 GM PART # 10372541
#2 GM PART # 10372542
2008 - 2010 later style
Blank Key GM PART # 25995382
#1 GM PART # 25926479
#2 GM PART # 25926480
You can use either the early C6 or later C6 style of fob with your 2008. Electronically they are all the same.
You can find comprehensive instructions on how to program them here:
http://forums.corvetteforum.com/c6-c...uctions-6.html
There is a slot in the left hand side of the glove box.
Insert your fob there with the buttons facing the passenger side.
Even with a dead fob battery, you can still start the car this way.
The other reason for using the slot is it has its own antenna and if you are in an area with high RF interference and your fob isn't working, it gives you the best chance of getting the fob to be recognized, so you can start the car.
the description is: Electrical - Body electrical - Keyless entry components - Transmitter Transmitter, corvette, w/o remote entry lock,
please note that description is "w/o remote entry." what does it mean?
St. Jude Donor '08-'09-'10-'11-'12
[QUOTE=Pauls72;1577555621]The only differance between a #1 and #2 is number on the back of the case. [QUOTE]
The number stamped on the case is just so you can tell them apart, otherwise they're identical.
I assume you still have your #2 FOB. Your FOB's have a p/n (part number) on the back, you can search on that p/n. You will find the p/n on the FOB is superseded by a new p/n.
#1 GM PART #25854929 ssby 25926479
#2 GM PART #25854930 ssby 25926480
This is important! All C6 fobs, regardless of year, are electrically identical. They will all fit in the glovebox slot and can all be programmed to the car as #1,2,3 or 4. The number stamped on them is only to indicate how they were programmed at the factory...YOU can re-program them in any order that you want. So if you find a good deal on a different number than you need, don't worry about it. Again, all C6 fobs are interchangeable as far as the way they actually work.
I don't have a clue why the description is like that, but that is what you need.
thanks alot, i really appreciate your helpful input.
Regards.
This was addressed in a March thread. Gene Culley said all those other FOB's are for export. His response:
All of the different frequencies are actually export or foreign FOB's. The one you guys need to order is the ones without the remote lock entry
Premium Supporting Vendor
Thanks for the referral. Feel free to give us a call or send us an email if you need assistance.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
