visor universal remote battery replacement
Old May 8, 2011 | 04:49 PM
harvey1228's Avatar
harvey1228
6th Gear
Default visor universal remote battery replacement
How do I replace the battery in 2006 corvette's visor mounted universal garage door opener?
Old May 8, 2011 | 05:12 PM
R&L's C6's Avatar
R&L's C6
As far as I know they are hard wired , no battery.
Old May 8, 2011 | 05:17 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Elmer
My first all smilie post!
Old May 8, 2011 | 07:00 PM
timd38's Avatar
timd38
We make it and it does not have a battery.
There is a wire connection were it goes into the A Pillar, but that's it. The connection also powers the mirror light.
Old May 8, 2011 | 07:24 PM
VET4LES's Avatar
VET4LES
Old May 8, 2011 | 08:58 PM
SRuizV's Avatar
SRuizV
where can i get a visor with the garage opener/homelink?
i just bought an 08 vette 1LT and it doesnt have that
Old May 8, 2011 | 09:37 PM
bbster's Avatar
bbster
Call Gene at GM Partshouse He will take care of you. The best in the business
Old Apr 8, 2022 | 11:33 PM
anchito27's Avatar
anchito27
Are the lights supposed to illuminate somehow when you press the buttons? Because mine aren't doing anything, but the mirror lights turn on.⁰
Old Apr 9, 2022 | 10:38 AM
CorvetteSparky's Avatar
CorvetteSparky
I don't think that there's any lights in those buttons.
Old Apr 9, 2022 | 04:17 PM
madsonp's Avatar
madsonp
Originally Posted by eboggs_jkvl
Elmer
Nice
Old Apr 9, 2022 | 04:27 PM
madsonp's Avatar
madsonp
There were two different systems used on the Corvettes, HomeLink and Car2u, HomeLink has a single LED while Car2u has three LED's, all of which are hardwired to the car (no batteries). Keep in mind that HomeLink isn't compatible with all garage door openers, in these instances a compatibility bridge may be required http://www.homelinkestore.com/Produc...ridge-Kit.html If your car was produced after 10/06 then you most likely have a visor control made by the car2u company (3 buttons and 3 LEDs, one over each button). Car2u is not a friendly as the the more popular homelink system. Often you need to purchase a universial adapter to get the visor to work with the garage door. https://www.doorsandoperators.com/pr...bility-bridge/ Assuming you have HomeLink, here's the instructions from the owners manual on programming it.
Programming the HomeLink® Transmitter:
Do not use the HomeLink® Transmitter with any garage door opener that does not have the “stop and reverse” feature. This includes any garage door opener model manufactured before April 1, 1982. If you have a newer garage door opener with rolling codes, please be sure to follow Steps 6 through 8 to complete the programming of your HomeLink® Transmitter.
Read the instructions completely before attempting to program the HomeLink® Transmitter. Because of the steps involved, it may be helpful to have another person available to assist you in programming the transmitter.
Keep the original transmitter for use in other vehicles as well as for future HomeLink® programming. It is also recommended that upon the sale of the vehicle, the programmed HomeLink® buttons should be erased for security purposes. Refer to “Erasing HomeLink® Buttons” or, for assistance, contact HomeLink® on the internet at: www.homelink.com or by calling 1-800-355-3515.
Be sure that people and objects are clear of the garage door or gate operator you are programming. When programming a garage door, it is advised to park outside of the garage.
It is recommended that a new battery be installed in your hand-held transmitter for quicker and more accurate transmission of the radio frequency.
Programming HomeLink®
Your vehicle’s engine should be turned off while programming the transmitter. Follow these steps to program up to three channels:
  1. Press and hold down the two outside buttons, releasing only when the indicator light begins to flash, after 20 seconds. Do not hold down the buttons for longer than 30 seconds and do not repeat this step to program a second and/or third transmitter to the remaining two HomeLink® buttons.
  2. Position the end of your hand-held transmitter about 1 to 3 inches (3 to 8 cm) away from the HomeLink® buttons while keeping the indicator light in view.
  3. Simultaneously press and hold both the desired button on HomeLink® and the hand-held transmitter button. Do not release the buttons until Step 4 has been completed.
    Some entry gates and garage door openers may require you to substitute Step 3 with the procedure noted in “Gate Operator and Canadian Programming” later in this section.
4. The indicator light will flash slowly at first and then rapidly after HomeLink® successfully receives the frequency signal from the hand-held transmitter. Release both buttons.
5. Press and hold the newly-trained HomeLink® button and observe the indicator light.
If the indicator light stays on constantly, programming is complete and your device should activate when the HomeLink® button is pressed and released.
To program the remaining two HomeLink® buttons, begin with Step 2 under “Programming HomeLink®.” Do not repeat Step 1 as this will erase all of the programmed channels.
If the indicator light blinks rapidly for two seconds and then turns to a constant light, continue with Steps 6 through 8 following to complete the programming of a rolling-code equipped device (most commonly, a garage door opener).
6. Locate in the garage, the garage door opener receiver (motor-head unit). Locate the “Learn”
or “Smart” button. This can usually be found where the hanging antenna wire is attached to the motor-head unit.
7. Firmly press and release the “Learn” or “Smart” button. The name and color of the button may vary by manufacturer.
You will have 30 seconds to start Step 8.
8. Return to the vehicle. Firmly press and hold the programmed HomeLink® button for two seconds, then release. Repeat the press/hold/release sequence a second time, and depending on the brand of the garage door opener (or other rolling code device), repeat this sequence a third time to complete the programming.
HomeLink® should now activate your rolling-code equipped device.
To program the remaining two HomeLink® buttons, begin with Step 2 of “Programming HomeLink®.” You do not want to repeat Step 1, as this will erase all previous programming.
To visor universal remote battery replacement
