Cabin Filter
May 10, 2011 | 01:59 PM
Cabin Filter
In my previous car it was recommened to change the cabin filter every other oil change so about every 20,000 miles. I am 17,000 so I was looking in the manual yesterdy where the cabin filter is..but could not find it...
Coupe C6
Thanks.
May 10, 2011 | 02:07 PM
Passenger side of the engine bay to the right of the battery on the firewall...
D
May 10, 2011 | 02:16 PM
Right behind the battery. Try page 3-31 in 2008 manual.
May 10, 2011 | 04:08 PM
You may be surprised by how much junk is in that filter. I would suggest checking it that often but it is easy to see if it needs changing or not. If the car is in a garage all the time, every other oil change may be more often than necessary.
May 10, 2011 | 05:30 PM
Just checked mine...I am ashamed of myself. It was filthy.
Advance doesn't have them here so i will have to try auto zone or the dealer.
May 10, 2011 | 05:37 PM
Is it easy to do even for the noobs?
May 10, 2011 | 05:42 PM
Quote:
Originally Posted by
04_Z06_CE
About as easy as it gets.
May 10, 2011 | 06:03 PM
purolator c-25623 order from Advance auto parts about $11.50
May 10, 2011 | 07:05 PM
eforce
This is what I did...OEM filter is outrageously expensive.
May 10, 2011 | 07:31 PM
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Very easy to replace. As noted it is in the engine compartment on the firewall just behind the battery on the passenger side.
It should be changed basically once per year (varies depending upon mileage.)
It is listed in the 2008 owners manual on page 3-31. It is listed in the index under Climate Control System, Air Filter, Passenger Compartment.
May 10, 2011 | 07:45 PM
Pep Boys stocks one of the Purolator on the shelf for about $12 also.
May 10, 2011 | 08:40 PM
Thanks everyone
talon90
Thanks everyone for all the great responses, I looked in the back of the owners manual by the air filter section. Also, looked in index under C for Cabin Filter....thanks again
May 10, 2011 | 11:00 PM
talon90
Very easy to replace...
Yes, it
should be... and plenty of folks report that it's easy.
But it sure wasn't for me:
http://forums.corvetteforum.com/c6-c...urprising.html
Especially see post #20 in the above link -- make sure to install it oriented correctly
and be careful not to tear it.
May 11, 2011 | 10:45 AM
TNTC4VETTE
They are all over the east side for less than $9
May 11, 2011 | 09:57 PM
St. Jude Donor '13
Someone said GM recently dropped the price of the filter, no details.
We changed ours at about 20k and it was filthy.
Just changed again today at 31k and it could have been reused.
May 11, 2011 | 11:26 PM
Premium Supporting Vendor
