Help!!!!!!
Old May 13, 2011 | 11:38 AM
Craig P's Avatar
Craig P
Default Help!!!!!!
After removing the door panels to do speaker up grades, my power windows will not go up. They powered down ok and you can hear a switching noise when you try to raise them, but they won't move.
I have tried disconnecting the battery, but it didn't help.
I have also throughly checked that all the wires are not damaged and there is no interference of any kind with the mechanical mechanism or window.
My only though is some how the electronic window limits are messed up?
Anyone know how to fix this?
Old May 13, 2011 | 11:47 AM
DC321's Avatar
DC321
Maybe new speakers are too deep, blocking the window frame from moving?
Just spitballing.
Old May 13, 2011 | 11:50 AM
Craig P's Avatar
Craig P
Nope, Checked and have now removed them
Old May 13, 2011 | 11:56 AM
bonnevillebill's Avatar
bonnevillebill
Electrical connector not fully seated?
Old May 13, 2011 | 11:57 AM
RicK T's Avatar
RicK T
Not sure what you did or what order you did it but once the battery is disconnected, the windows have to be re-indexed AND the doors have to be closed before they will work. So, close the door(s) and raise the window(s). That should do it.
Old May 14, 2011 | 10:04 AM
Craig P's Avatar
Craig P
Thanks, everything was perfectly ok, just didn't have the doors closed.
Old May 14, 2011 | 10:33 AM
pittperson's Avatar
pittperson
These are some damn picky cars!
To Help!!!!!!
