Vibration problem on 08 Vert
This started when I had new PD2 AS Michelin tires installed at Discount Tire.
I went back much later, thinking the tires may need to break in.
I went back to DT the checked the balance, and found one wheel bent.
I had a new wheel installed today, to replace the bent one.
Same vibration, does anyone have a suggestion as to how to go about locating the problem?
I may find a small tire dealer, so I can be there to check each wheel myself.
DT frowns on people in their bays, not to mention they are so busy they don’t have time to let me check each wheel as I would like to.
I have a dial indicator, so I need to find a shop that will let me put each wheel on the ballancer and check them myself.
I did have the balance rechecked already.
That;s when they found the bent wheel.
I do have the "Service Ride Control" come on every once in a while. But usually after driving a while, when I restart, it goes away.
They told me it was bent/warped, and I looked at it on the balancer.
I could see it wooble.
Matter of fact I can't believe I couldn't/can't feel it at lower speeds.
I will check to be sure all tires are the same.
Not to change the subject, but I cringe every time I have to have someone else work on my car.
Just like having the wheel installed at DT this morning.
The guy pulled it out, and was sitting in it pushing buttons.
So I went out, and he told me it was ready to go, but he knew the tpms was working but couldn’t get it to set like it should. I told him to get the instructions, and it will work., He did and it did.
I went thru this when they put the tires on. Four different guys took turns getting my car, and each one pushed every button they could find. Finally one decided to get the instructions, and it took less than one minute.
A few minutes ago I went to one of those Quick oil change places (It was the last time). I just needed to get it changed today. When they finished two guys did the same thing, taking turns getting in and pushing buttons. I came out, and one told me I had to leave the service area. I told him he could kiss my A$$. It’s my car, and I want to see what they were doing. My first thought was there wasn’t any oil pressure. But all it was, them trying to reset the oil life. They were even pushing the HUD buttons.
I told them how to set it, and also told them it’s not really rocket science, especially when he had already gone back in the office, and printed out how to reset it on a 08 Corvette.
Sorry, I just had to vet a little.
still, I'd go first for the road force balance (Hunter 9500,9600, etc.).
The wheel I relaced was the right rear.
The wheel apeared to be warped (like from mounting) rather than it hit something.
They are factory Gumby chrome wheels.
How-ever I did replace it with a replica.
The copy wheel looked good (I know that doesn't matter), an even though I didn't weigh them, they seem to be close to the same weight.
This give me a few things to try.
as to finding a Hunter dealer, http://www.gsp9700.com/. you'lll get a site where you can plug in your zip and it'll list out all stores in your area.
As usual they offered for me to bring it in, and they would check the balance.
As things were, and with my procrastination 6 months before I made it back in.
So I didn’t push the issue, since it was my fault not going back right away.
I even remember one of the guys having a lot of trouble taking the old tires off, and eventually having to get help.
Didn't think anything of it then, but I believe this was when the rim was warped. He was prying on it pretty hard, with a 3 foot bar.
The good news I watched him balance each one, and he said all the wheels were within specs,
Which means none were bent or warked.
However, went for a road test, now the vibration is 10 times as bad.
Before it was a mild vibration, that only I could feel.
Now the whole car vibrates at 80-MPH.
So I will go back tomorrow, and let you know what happens.
I'm thinking a weight must have fallen off.
Because he had one fall off while balancing one of the wheels.
Also now the steering wheel shakes, and before it was only in the rear.
I did look the aftermarket wheel also had the relief for the tin nuts.
I'm back to the way it was before the first Road force balance.
I ask if his machine had been calibrated. He said they calibrate them every week.
But every tire/wheel was out of balance.
He even had to bust the tire loose, and rotate it on the wheel.
I don't see any reason to just keep going back, doing the same thing over and over.
I'm going to just bite the bullet, and live with it for a while.
Like I said I think if anyone was in the car with me, they would never notice the vibration.
It may just be the tread on the Michelin Pilot Sport AS/ZP tires.
If noting else, I'm going to find someone that I think really knows what they are doing with the Hunter 9700 balancer.
