Silly question, but is lowering a Corvette a painstaking process? Is it hard on the body of the car or make the overall life of the car any shorter? Any links about the process, recommendations, and opinions are greatly appreciated.
Also, I'm assuming it will void any warranty that is on the car, correct?
NO & NO it will not void the warranty.
Reason: change a word
Lowered mine last month all the way down on the stock bolts. This is very easy especially if you have access to a lift. Only get about one half inch or so but it is noticable. I did buy a set of lowering bolts but it looked like it was going to be a pita. May still attempt to install them later on. Good luck. Marc L.
Just make sure you grease all of the joints if you change the bolts. I didn't grease mine and the car started squeaking and clanking. It's going on the lift tomorrow to get re-done and greased.
I lowered mine on stock bolts and the front looks great but the back still sits too high for me. Any issues with throwing a set of hardbar lowering bolts only on the back?
Lowering the Corvette is really just a turn of the lowering bolts away. That being said, it's pretty easy to go too low on even the stock bolts. The lower the car goes, the more suspension travel you tune out of the system. This can lead to your car riding on the bump stops on the shocks more often than is recommended. Not only does hitting the bump stop upset the balance of the car, but riding as low as possible may end up damaging the shocks.
The most effective longterm solution to lowering your car are adjustable coilovers. With our coilover kits you can lower your Corvette without losing suspension travel, this keeps both your bump stops and your back happy.
