Lowering a C6 Video
Old May 17, 2011 | 09:57 PM
Vega$Vette's Avatar
Vega$Vette
Default Lowering a C6 Video
So simple a geezer can do it one handed while holding an Iphone
Front
Rear
Key is to get the weight of the Vette off the A-Arm. Do it with out jacking the spring and you WILL strip the head of the bolt.
Little WD40 on the treads doesn't hurt?
Old May 17, 2011 | 10:05 PM
gvette98's Avatar
gvette98
very cool thanks
Old May 17, 2011 | 11:51 PM
smurfkiller's Avatar
smurfkiller
sticky please
with all the questions on how to do this, please make this permanent
Old May 21, 2011 | 01:50 AM
mr.aqua's Avatar
mr.aqua
Thanks for sharing. I just lowered my car. I didn't have ramps so I jacked up the car using the the sides and then used a bottle nose jack on the arms. Gently lowered the car on the arm sprayed the bolt with WD-40 and then turned. Pretty simple and best of all FREE!
Old May 21, 2011 | 12:23 PM
speedraider's Avatar
speedraider
Good job...........
Old May 21, 2011 | 01:21 PM
Oldfly's Avatar
Oldfly
Thanks for the video, you made it real plain were the bolts are located.
Old May 21, 2011 | 01:24 PM
GS-Zero's Avatar
GS-Zero
Sticky this now
Old May 21, 2011 | 02:01 PM
mikez51c6's Avatar
mikez51c6
St. Jude Donor '11
Nice vid thanx
Old May 21, 2011 | 02:13 PM
Xedes's Avatar
Xedes
Tagged!
Old May 21, 2011 | 02:51 PM
FAsnakes's Avatar
FAsnakes
Veteran: Marine Corps
Perfect.. .
Called a local shop and they wanted like $400 bucks to lower on stock bolts..
Old May 25, 2011 | 05:36 PM
legbuh's Avatar
legbuh
What about alignment when done.. and do you just lower them all the way or do you count turns/etc? I want to do this but don't want to mess anything up.
Old May 28, 2011 | 03:19 AM
KLRBEE2's Avatar
KLRBEE2
Any pics of the car before and after lowering...at least lowered?
Nice Job!
Old May 28, 2011 | 04:05 AM
AmitZ06's Avatar
AmitZ06
Nice!!!!
Old May 28, 2011 | 10:55 AM
ripptide56's Avatar
ripptide56
So how much does this lower the car?
Old May 28, 2011 | 11:31 AM
soulcoaxing's Avatar
soulcoaxing
Acct suspended by request 21 Sept 2011
Default Questions
Great job and thank you!
So, now my curiosity is running rampant. What, if any, implications are there for alignment issues with the front: camber, caster, tow-in, tow-out, and anything else I don't understand fully. In addition, my car has the select ride control, so does lowering adversely affect those $2k shocks by adding a burden to them, or by limiting their performance, etc.?
I have similar questions for the rear since it is independent rear suspension and possible alignment issues. I'm definitely no expert, don't even know if I employed the terms I used correctly, but I am very interested in learning, understanding and would appreciate anyone's attempts to share their knowledge. I did note too that you lowered it all the way, as you said. If one lowered them less than all the way, I suspect you would take a reference height somewhere to enable matching the height on the opposing wheels, or?, and perhaps elucidation on that topic would be helpful to all of us less knowledgeable, and interested.
I may be mistaken, but I believe that any misalignment may accelerate tire ware, and/or lower gas mileage, just to name two more concerns (I) harbor. Thank you kindly.
Old May 28, 2011 | 12:05 PM
gomerboat's Avatar
gomerboat
Nice job....so easy!
Old May 28, 2011 | 02:26 PM
NOCRISIS's Avatar
NOCRISIS
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
To Lowering a C6 Video
Old May 28, 2011 | 02:49 PM
Blaq Ops's Avatar
Blaq Ops
please sticky
Old May 28, 2011 | 03:07 PM
Ahmer's Avatar
Ahmer
Get your alignment done, otherwise your tires are toast!
Old May 28, 2011 | 03:09 PM
SlayerRX8's Avatar
SlayerRX8
Nice Job!
x2....before and after pics would be nice.
