2005 convertible
Old May 18, 2011 | 11:19 PM
charlene miller's Avatar
charlene miller
2nd Gear
Default 2005 convertible
I am having problems with putting the power top down. When the button is engaged, the windows come down and the top starts to go down, but then stops halfway and the deck lid will not open for the top to go into. Does anyone have a solution??
Old May 18, 2011 | 11:27 PM
vettedoogie's Avatar
vettedoogie
I'm guessing it is a position sensor out of whack. You might check the trunk area to make sure the "partition" is fully/correctly engaged. Any DIC messages?
Old May 18, 2011 | 11:35 PM
charlene miller
2nd Gear
no there are no messages, and the partition is fully in place.
Old May 18, 2011 | 11:55 PM
mojoman's Avatar
mojoman
Sometimes the top is stubborn and just needs a little push from you to make it function properly. Give it a little push, and it should continue to do it's disappearing act for you. It has happened to me on occasion.
Old May 19, 2011 | 12:22 AM
nuklhd's Avatar
nuklhd
St. Jude Donor '09
Mine has done this on occasion and it has always been that the partition was not fully engaged. It appears to be but when I "unsnap" it and "resnap" it it works as it should. You may want to try this. Just a thought and hope that is all it is.
To 2005 convertible
