Engine shutter
Old May 21, 2011 | 04:03 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Default Engine shutter
I seem to have a very pronounced engine shutter under wide open thottle. I am doing some fine tuning and before ever making any changes the shutter began.
Under WOT theirs a harsh shutter and noise, not sure if noise is engine, but will eventually smooth out. Looking at the run log in HP Tuners I don't really see anything that gets my attention. There's a little bit of retard briefly and looks to go a little toward lean but nothing major.
I have tried 3 or 4 previous tunes that did good under WOT previously but these also have the shutter. It only does it under WOT. I can speed up very fast but less than WOT and not have the shutter.
Where do I start to try and narrow down what this is?
Thanks in advance.
Old May 21, 2011 | 05:10 PM
Larry/car's Avatar
Larry/car
That toward lean condition could be causing detonation. Detonation can cause engine damage. Under high power I would think you should be slightly rich.
Old May 21, 2011 | 05:43 PM
rchbn's Avatar
rchbn
Insert joke here < >
Thank you, I'll be here all the week, try the veal!
Old May 21, 2011 | 07:07 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
I just ran and logged. The only thing I see is at WOT my Commanded fuel drops from 14.68 to 11.38 I don't remember if this is normal or not. Everything else just kinda flatlines.
Old May 21, 2011 | 07:20 PM
laconiajack's Avatar
laconiajack
Thanks in advance.
Have you consider restoring the factory "tune", or is this now impossible?
Old May 21, 2011 | 07:36 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Yes I have and still the same shutter just different response from the engine, performance wise.
Old May 21, 2011 | 08:05 PM
EDinPA's Avatar
EDinPA
How about something simple, cracked coil? Weak spark, bad plug / wire, bad wire connection?
Old May 21, 2011 | 08:21 PM
OregonC6's Avatar
OregonC6
Cameras and houses have shutters while cars sometimes have shudders. Cows on the other hand have udders and so it goes.
Might be the gasoline ( octane ) you are using?
Old May 21, 2011 | 09:09 PM
Motorhead-47's Avatar
Motorhead-47
Start with a set of fresh spark plugs.
Old May 21, 2011 | 09:18 PM
Motorhead-47
Normal...car drops into PE (Power Enrichment) mode at WOT. 11.38 AFR is a bit rich for your car but that isn't your problem. Something closer to 12.8 would be better. Under the Engine heading, Fuel tab, power enrichment tab, "EQ Ratio vs RPM" button. Numbers in the cells equate to an AFR value. 14.7 (stoich) divided by the value in the cell is your commanded AFR. "Flatlines" I'm guessing refers to your fuel trims?..normal in PE mode.
Old May 21, 2011 | 09:23 PM
Motorhead-47
Are you datalogging "Misfires" ? If not, recommend you add that PID, log a run and see if you are seeing any misfires.
Old May 21, 2011 | 09:24 PM
cthusker's Avatar
cthusker
... sounds more mechanical then tune related to me. I'd be looking at coil packs, plugs, wire.... If you've put it back to stock tune and it's actually stock then you can almost bet it's not tune related... Since your not tossing any codes it's hard to say with any certainty... Good luck and keep us posted what you eventually fine...
Old May 22, 2011 | 12:41 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
I have some known good plugs and wires I'll try tomorrow morning. I'll also add the misfire PID to the scan. Want to see one when ready?
I'm glad I noticed this and hopefully can fix it quick before Talladega next weekend.
Whatcha doin tomorrow?
Old May 22, 2011 | 12:45 AM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Yeah I used two stock tunes and a couple of other known tunes. I don't drive hard hardly ever but was on a dark lonely country road the other night and decided to air it out a little.
I was not pleased but I cannot remember the last spirited run so I am not sure when the problem came around. It idles and drives normal otherwise and gas mileage hasn't suffered even on interstate trips at speed.
Old May 22, 2011 | 12:58 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
I'd shudder if my engine shuttered.
Old May 22, 2011 | 07:10 AM
Motorhead-47
Robert,
Swap those wires and plugs and then log the run. If the shudder is still there email me a copy of the log.
ken
Old May 22, 2011 | 12:30 PM
CO Lightfoot's Avatar
CO Lightfoot
Originally Posted by OregonC6
...Might be the gasoline ( octane ) you are using?
Maybe you got a tank of bad gas... try some octane booster and Techron cleaner?
I believe the C6 retards the timing if detonation is detected. Maybe this causes your shudder.
To Engine shutter
Old May 22, 2011 | 01:27 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Robert,
ken
Now that the hottet part of the day is here I'm going out to take care of this. PM me your email. For some reason I cannot find a single email from the past.
I run through a tank or two of 93 a week and from different stations so probably not this but thanks for the suggestion. May run some injector cleaner anyway though.
Old May 22, 2011 | 01:38 PM
JoesC5's Avatar
JoesC5
Hope you get it figured out by Saturday, to run at Talladega. I've been checking the Weather Channel twice a day for the past week and they still keep chance of rain in the forecast for Thursday through Saturday. We have 30 cars drivng down and I would hate to be rained out. If anyone knows anyone at the Weather Channel, could you contact them and have them forecast clear sky's for next weekend.
Old May 22, 2011 | 02:39 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
I just pulled the plugs and wires. All the wires check out cold. The iridiums though look to be worn. 1 has 0.40 gap the rest are beyond 0.65 gap. May be the problem. Electrode looks to be burn badly.
Luckily the shutter is only on WOT. I can ramp up the speed fairly fast without the shutter. If all else fails and I break something at least then I'll know what it was.
Try to look us up at Dega. Our car number is 173, Yellow Vert, Black Carbon headlights. I'll have a T on with a big "Jake" on the back. What position at you?
