Door Lock Question
Old May 23, 2011 | 01:06 PM
okie08vette's Avatar
okie08vette
Default Door Lock Question
OK, how come after a few minutes my car doors lock even with the FOB in the car? Is there a setting I need to change? I though the doors would not lock as long as the FOB was in range, espically if the FOB was in the car?
Old May 23, 2011 | 01:31 PM
Hoonose's Avatar
Hoonose
Look in DIC options to turn off autolock
Old May 23, 2011 | 01:49 PM
Tin Star's Avatar
Tin Star
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
The doors locking with the FOB inside the car is a safety issue otherwise driving through the hood they would jack your ride at a signal light.
Old May 23, 2011 | 01:57 PM
Vette_DD's Avatar
Vette_DD
If you're talking about the doors locking when a fob is left in the car and the engine is not running, it's only supposed to do that if at least one fob has been removed from the car.
If you have a reason to leave a fob in the car, reprogram it so the car does not automatically lock.
Old May 23, 2011 | 02:06 PM
okie08vette
Great, Thanks
Old May 23, 2011 | 02:11 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The car is desined to look for the primary fob in the car. The primary fob will be the only fob or if there is more than one, the fob with the lowest number. If the primary fob has left the vehicle and the secondary fob remains in the car and the autolock is set to on, the doors will lock. If the only fob it detects remains in the car it will not lock the doors.
The car does not look for the fob if a door has not opened since the time it was closed and the fob was detected meaning it will still lock the doors once you get in and the vehicle is started.
Much more important than any of that above. The car will only search for a fob in the drivers compartment. It will NOT find nor will it look for a fob in the rear hatch area. If you are trying to toss your fob in the back in a briefcase or golf bag, it will lock the doors. It is simply not designed to look there for the presence of a fob. Think of this like your conventional car. If you put your keys in the trunk and close it, it will be locked. The Corvette looks only in front of the front seats.
Old May 23, 2011 | 06:55 PM
haljensen's Avatar
haljensen
Easiest solution is to remove the passive locking in the "Options". The Owners Manual explains it pretty well.
Then YOU have to lock the car with the button on the fob every time you leave the car.
Old May 23, 2011 | 07:09 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
a much wiser choice, imo....
Old May 23, 2011 | 07:26 PM
cclive's Avatar
cclive
Old May 23, 2011 | 09:15 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
You can also turn on "Fob Reminder" using the DIC and then the horn will chirp 3 times if you close the door with the ignition off and the fob still inside the car.
Old May 24, 2011 | 09:28 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
These guys answered your question. Good luck!
Let me know if you need anything and I will do what I can.
Brent
GM Customer Service
Old May 24, 2011 | 11:33 AM
okie08vette
Brent
GM Customer Service
Thanks Brent, I understand my options now not sure what I will change yet but Thanks for the input.
Old May 24, 2011 | 02:09 PM
06 C6 vert's Avatar
06 C6 vert
I like to roll with all the auto lock on, fob reminder yada yada.
So let me get this right! Passanger door always locks when you are driving but not the driver door?
Old May 24, 2011 | 02:23 PM
Drewstein's Avatar
Drewstein
Much better option than turning off one of the best features of the car.
To Door Lock Question
