Double Din Install Bracket
Old May 23, 2011 | 07:39 PM
jahastings's Avatar
jahastings
5th Gear
Default Double Din Install Bracket
In there a bracket or faceplate that allows the use of the DIN sleeve that comes with the new double din radios? I have the Metra 95-3305 and am trying to install in my C6 and the only way I can see is to screw the bracket to the radio. Was hoping to use the sleeve system.
Old May 23, 2011 | 08:03 PM
RicK T's Avatar
RicK T
If you don't get any answers here, contact C5 Bearsfan and ask OR post in the Audio/Electronics Forum.
http://forums.corvetteforum.com/c6-c...ants-them.html
http://forums.corvetteforum.com/audio-electronics-20/
Old May 23, 2011 | 09:31 PM
Dave O's Avatar
Dave O
Not too sure what you mean by the sleeve system. I just installed a double din and needed the metra kit to complete the install. However, I used the 95-3304 supplied by Dennis at Double D Mods. Not too sure what the difference is. Yes, you have to screw it to the radio. Only takes a couple of minutes, and after that, just slips right into the opening and attaches just like the stock head unit.
For more info, contact Dennis (C5 Bearsfan) as noted above.
To Double Din Install Bracket
