A little help needed
Old May 24, 2011 | 09:31 PM
supercoupe5's Avatar
supercoupe5
6th Gear
Default A little help needed
Have a little bit of a problem that i can not find an firm answer on. We have a 06 Vette. On Friday we will have a new addition to the family. Is it possible to put a rear facing car seat in a Vette? Thanks much. Dave
Old May 24, 2011 | 09:32 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
not in the front seat though right? in the back area?
Old May 24, 2011 | 09:50 PM
supercoupe5
6th Gear
Back area? i need to put the car seat in the passanger seat if possible.
Old May 24, 2011 | 09:51 PM
cclive's Avatar
cclive
Unless there is 80 pounds or more on the passenger seat, the airbag will be de-activated. It will show whether it is activated or not on the rearview mirror...to confirm it. If the airbag is de-activated, then it should be just like being in the front seat of any other car.
Old May 24, 2011 | 09:57 PM
moolys's Avatar
moolys
St. Jude Donor '09
I had my daughter in a seat till 5 no problems
supercoupe5
6th Gear
is there a way to deactivate the air bag other than less than 80 pounds in the seat?
Old May 24, 2011 | 10:10 PM
cclive's Avatar
cclive
In '05, it was a keyswitch but in '06, they went to the automatic 80 pound sensor. And of course you would want the airbag back on again when an adult is in the passenger seat, so probably not a good idea to bypass the sensor, though probably easy to do.
Old May 24, 2011 | 10:14 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Check with GM
To A little help needed
