bogus f55 switch?
May 25, 2011 | 06:57 PM
bogus f55 switch?
My 2005 Has the selective magnet ride control switch however, this function does not seem to work and is not listed on the glove box list of options.I'm 4th owner and suspect that the switch has been changed.How can I find out if this feature is on my car.
May 25, 2011 | 07:11 PM
Look for the RPO code "F55" on the sticker on the inside of the glove box door. They're in alphabetical order.
May 25, 2011 | 07:14 PM
Ask a friendly dealer to check it out or where you purchased it.
May 25, 2011 | 07:39 PM
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
It is very difficult to identify the difference by just turning the switch.
A search of this forum will help you understand how to check the system to verify that it is working but even then the change is subtle and difficult to tell.
May 25, 2011 | 07:45 PM
Some people have added the switch to turn NPP on and off.
May 25, 2011 | 08:12 PM
St. Jude Donor '08-'09 & '12, '14
Check if you have wires going to your shocks
May 25, 2011 | 08:40 PM
if your shocks have wires then you got it....and for the record, its worthless. I had it on my c5 and on my c6 now...waste of money
May 25, 2011 | 08:43 PM
Quote:
Originally Posted by
StKnoWhere
He is asking about the suspension - not the exhaust.
May 25, 2011 | 08:45 PM
Maites
Really? Most that have it swear by it....Curious what didnt you like about it.
May 25, 2011 | 08:49 PM
BadToo
I think SKW was merely suggesting that if it is in fact bogus that maybe a previous owner installed it up to operate a NPP exhaust system....
May 25, 2011 | 08:57 PM
Maites
Strange, I have had both Z51 and F55. I prefer F55.
May 25, 2011 | 09:08 PM
Maites
Just your opinion.
boraxman
Must not have had any rough roads to drive on.
Tin Star
I never had the Z51 option, but I had both base suspension and F55. The F55 was noticeably better than the base suspension on rough roads.
May 25, 2011 | 09:28 PM
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Maites
Well...you'd probably never notice the improvement it provides just driving to and from your local 7 Eleven
May 25, 2011 | 09:37 PM
C7 of Year Finalist (stock) 2019
The mere fact that it doesn't feel any different on or off makes you wonder what its value is...
If you're not going to notice it going to the local 7 Eleven, where ARE you going to notice? If you are out on the highway, that's a nice smooth ride anyway, so what else is there?
May 25, 2011 | 10:38 PM
boraxman
Correct and thanks.
May 25, 2011 | 11:13 PM
No contest here - F55 is THE way to go.
May 25, 2011 | 11:15 PM
SolidlyStated
So you think all roads everywhere are nice & smooth? Haven't been around much, have you?
May 26, 2011 | 12:33 AM
Cruise-In III Veteran
St. Jude Donor '11
JimTN
Probably only to his local 7 Eleven.
May 26, 2011 | 12:50 AM
there was a problem with some F55 systems not engaging properly, check the C6 FAQ to make sure you are not experiencing the same thing.
May 26, 2011 | 02:31 AM
St. Jude Donor '11-'12-'13-'14-'15
It could be that the previous owner replaced the center section/radio bezel with one from a different car that did have F55.
If it's not listed in the RPO Codes in the glove box and you're still unsure, have your VIN checked.
As for the comment about the F55 option being worthless, pull your head out.
