help leaking coolent 1971
Old May 27, 2011 | 07:27 PM
tacjam3's Avatar
tacjam3
Default help leaking coolent 1971
I am leaking anti freeze above gas pedal. What do think heater core or lines not an ac car. havent gotten chance to look under there yet it just happened. Didnt think there were lines there.
Old May 27, 2011 | 07:31 PM
Rocketmanwpb's Avatar
Rocketmanwpb
If the leak is on the inside of the passenger compartment you have a leak in the heater core or a line connecting to it. Are you certain it is coolant and not water from the condenser. If it is water then you most likely have a clogged condenser drain which is easy to remedy by blowing air up the drain hose from the underside of the car.
Old May 27, 2011 | 09:34 PM
etaylor14's Avatar
etaylor14
If it's leaking inside the car,it's the heater core seeing you don't have a/c
Old May 27, 2011 | 09:49 PM
tim414's Avatar
tim414
St. Jude Donor '12
Old May 27, 2011 | 10:13 PM
cclive's Avatar
cclive
I agree with the above and I have to add that all C6s have air conditioning.
Old May 27, 2011 | 10:19 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
you mean there isn't a 1971 C6?
Old May 27, 2011 | 11:46 PM
cclive's Avatar
cclive
Yes Bill, That's the '71 big block 454 C6....
To help leaking coolent 1971
