Brake Pads?
Old May 27, 2011 | 11:45 PM
TSLAVette's Avatar
TSLAVette
Default Brake Pads?
Have the F55 with drilled rotors (Z51 brakes). Have a squeak in LR wheel that drives me crazy & dust big time on the chrome aluminums. So ...
1. Ceramic or stick with stock pads? Just driving around town; no plans to autocross/track
2. If ceramic, which ones? I've read about Hawk Performance Ceramics, CarboTech (need 2nd mortgage and have read they wear fast) and Delco
3. If stick with stockers, how do you get rid of the squeal in the LR???
I suppose that I'll also change the brake fluid since its the original from 3/2008. Any suggestions on the best fluid for these cars??? Thanks
Old May 30, 2011 | 05:14 AM
BILLD518's Avatar
BILLD518
I hope someone gives you some advice on this.
I'm trying to decide the same thing.
Old May 30, 2011 | 06:52 AM
MINI&aVette's Avatar
MINI&aVette
I've tried all the ones on the forum and the only ones that don't make noise or dust are Akebono. You don't have to Bed them and there is 0 dust. I changed over to Z06 brakes and Hawk ceramic pads and there is 3 times the dust my Akebonos put out and there not very expensive search the web.
Old May 30, 2011 | 06:57 AM
cthusker's Avatar
cthusker
Here's the pads I've been running for over a year with excellent results.... I have the same suspension with slotted/drilled rotors. Brake dust is minimual and stopping power is excellent....... They were bedding in properly and I have ZERO squealing with this setup... Check for pricing but the prices are what I paid which included shipping!
Brake Pad Set EBC Brake Pad Set Corvette|Base EBC Price: $84.30 Qty: 1.00 Part #: E35DP31160C
Brake Pad Set EBC Brake Pad Set Corvette|Base EBC Price: $126.98 Qty: 1.00 Part #: E35DP31162C
EBC REDSTUFF BRAKE PADS, CERAMIC, 2-WHEEL SET
Amazing stopping power is guaranteed with EBC Redstuff Brake Pad Set Series. Especially engineered for high-horse power imports, muscle cars, and prestige European cars, this product line has been proven to increase stopping power by a whopping 30 percent! Featuring a Kevlar-based compound that is enhanced with ceramic particles, Redstuff Pads have a higher-than-OEM heat threshold for resistance against brake fade, incredible bite from cold, a low dust rating, and long product life. All of these features make Redstuff Pads perfect for repeated heavy braking during fast street use. With EBC Redstuff Brake Pads, you have full confidence in the braking power of your vehicle.
Features:
Asbestos-free
Made from a innovative blend of Kevlar fibers and enhanced ceramic particles
Produces 60-90 percent less dust than OE pads
Brake bite from cold is as good as OE or better
Brake performance only increases as the pads heat up
Built with shims, slots, and chamfers for silent braking
Coated with Brake-In compound for faster break-in and greater initial braking effect
Old May 30, 2011 | 07:18 AM
fred_S's Avatar
fred_S
Or you could go with EBC Bleustuff NDX, a new development. I have them on my car and they don't squeal only minimal dust, the dust you get is easy to remove.
http://www.ebcbrakes.com/automotive/...ng/index.shtml
Old May 30, 2011 | 07:41 AM
cthusker's Avatar
cthusker
The reason I didn't go with the Blue pads is I don't track mine and wanted brake dust to be minumual. The mixed ceramic does a great job of that without giving up much braking power. The Blue was pushing 300 bucks for a complete set which I thought was a little pricey just for street use pads.....
Old Jun 1, 2011 | 09:38 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
If you want to do ceramics then you can use the Hawk or GM ceramics. We have had great luck with both! The only trick to any new brake pads is resurfacing or scuffing up the rotors and bedding in the new pads. If you don't bed in the new pads, there will be noises. Other than that, ceramics provide low dust and low noise.
Old Jun 1, 2011 | 10:46 PM
StKnoWhere's Avatar
StKnoWhere
I installed Akebono on my wifes G35 and had the same experience but also suffered an increase in braking distance, more noticeable when cold. The G35 like the Vette has excellent brakes so you are still able to out brake most cars on the road, other people may not notice the difference, just something to be aware of after you switch.
My preference is Carbotech, when bedded properly, low dust and noise, I've gotten good life and they are gentle on the rotors Great linear modulation, the harder you press the brake peddle, the progressively more braking torque you get.
Old Jun 1, 2011 | 10:49 PM
Tom_Slick's Avatar
Tom_Slick
I used to have a lot of squeaks before swapping out my stock rotors for slotted/ drilled ones and adding Hawk ceramic pads.
Old Jun 2, 2011 | 10:06 AM
Brakemotive's Avatar
0Brakemotive
Former Vendor
St. Jude Donor '11-'12-'13
As long as you're not doing any track days, a ceramic pad is the best choice IMO. The Power Stop Evolution Ceramic pads we carry provide excellent stopping power with minimal dusting and no noise. A complete front/rear set is only $60.00 shipped in the contiguous 48. Check out the link in my signature for product info and customer reviews!
To Brake Pads?
