computer glitch??
Old May 30, 2011 | 07:49 PM
AK Drop Top's Avatar
AK Drop Top
Default computer glitch??
It happened to me has it happened to you, and what did you do to fix?
couple days ago i go to get in the 08 C6 vert, and the door will not open. FOB is good. Had to break in by using the passenger door which still worked (weird). So after not being able to get in on the drivers side for about 2 hours, the car if off and now the button works. OK, i say no big deal. But now upon entering the car the easy exit mode goes into the driver mode and the seat and steering colum start to index into the driveing mode while Im standing outside.
So I reset all settings for driver and easy exit modes. Checked the DIC and toggled the settings. Now sometimes it workes but most of the time when I open the door, the seat automaticlly start to move into the driving position wiht the car off. Its supposed to happen when you start the car. I dunno!!
Anyone got a clue??
Old May 30, 2011 | 07:54 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Disconnect the battery for a few minutes. Hook it back up, index the windows and reset your settings with the "Button press" for 5 seconds for the double beep. Some time you have to clear the damn things brain and start over.
Elmer
Old May 30, 2011 | 08:05 PM
themaffeo's Avatar
themaffeo
sounds more like an electrical issue rather than a computer issue.
Old Jun 7, 2011 | 01:10 AM
AK Drop Top
Electrical, OK sounds like it could be. Details?? Lose connection or maybe H2o on wires? It did start to malfuntion after a wash. After a day, car back to normal, so even if I took it to the dealer for diagnostic, they gonna tell me every thing is fine, nothing found. Any Ideas from you guru's??
Thanks,
To computer glitch??
