Window problem
Old May 31, 2011 | 12:02 AM
dirt3434's Avatar
dirt3434
2nd Gear
Default Window problem
My 05 sits in the garage and is at best, a weekend roller. The battery died and I charged it back up and all is well. However, now the windows dont roll back up when I shut the doors like they are supposed to do. . .. .Any help would be appreciated.
Old May 31, 2011 | 12:08 AM
bluez06ny's Avatar
bluez06ny
You need to do this:
Power Window Initialize
After a power reconnect such as
battery replacement, the window
index‐up feature will not function
until the system is initialized.
Once power is restored:
1. Close the door.
2. Raise the window and hold the
switch up for three seconds after
the window is closed.
3. Release the switch, then
hold the switch up again for
three seconds and release.
Old May 31, 2011 | 12:29 AM
dirt3434's Avatar
dirt3434
2nd Gear
That did the trick, thanks so much. I appreciate it. . .
Old May 31, 2011 | 12:42 AM
Vette_DD's Avatar
Vette_DD
It's in the owner's manual.
Old May 31, 2011 | 06:39 AM
Roush's Avatar
Roush
St. Jude Donor '11-'12-'13
Old May 31, 2011 | 06:51 AM
ATC399's Avatar
ATC399
Originally Posted by Roush
Thanks for the early morning laugh
Old May 31, 2011 | 07:03 AM
C7Joy's Avatar
C7Joy
Old Jun 1, 2011 | 10:19 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
You will need to re-index the windows. This has been covered on the forum multiple times. A search for it should bring you results easily.
Good luck,
Brent
GM Customer Service
To Window problem
