Interesting
Old May 31, 2011 | 08:58 AM
GTJim's Avatar
GTJim
Default Interesting
So I was on the Chevrolet site checking to see if they had updated it yet to include info on the 2012's. Checking the specs between the different models of Vette's I noticed that GM has the base coupe listed at 3208 lbs and the Z06 at 3175 lbs. So the base is only 33lbs heavier than the Z06 ??? I thought there was a bigger weight difference than that.
Disclaimer: I'm not bashing the Z06 as I own one.
Old May 31, 2011 | 09:01 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
one would think that certain things (ie suspension and motor) were heavier, so things were changed to lighten it up??
Old May 31, 2011 | 09:03 AM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
it's that gigantic motor you have vs. the little whimpy Ls3... us base coupes have no weight cause of lack of frills...........
Old May 31, 2011 | 09:06 AM
GTJim's Avatar
GTJim
Actually you may be on to some thing. With all the new additions to the Z06 maybe it has gotten a little more portly.
Edit: Motortrend has the original Z06 weight listed at 3132lbs.
http://www.motortrend.com/auto_news/...z06/index.html
Old May 31, 2011 | 05:20 PM
cnw's Avatar
cnw
I found the GS vert is 28lb less than the Z06. This was 6 or 8 months ago when I checked.
Craig
Old May 31, 2011 | 08:16 PM
cclive's Avatar
cclive
The difference was 47 pounds in 2007.
Old May 31, 2011 | 09:59 PM
hawkgfr's Avatar
hawkgfr
Its 257 when I'm sitting in mine...
Old May 31, 2011 | 10:14 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Your right, those great big pistons in the Z06 are much heavier than the wimpy little pistons in the base coupe.
Oh ya, and those massive big beefy man-sized stabilizer bars on the Z06 weigh a ton compared to those pencil sized stabilizer bars on the base coupe!
Old Jun 1, 2011 | 06:44 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Craig
You might want to check that again.
Old Jun 1, 2011 | 09:14 AM
KneeDragr's Avatar
KneeDragr
How does that compare to the weight listed on the title? My title lists my GS at 3233lbs.
Old Jun 1, 2011 | 11:28 AM
cnw's Avatar
cnw
Foremaw,
You are correct. The 2011 ZO6 comes in at 3175lbs. The GS Vert is at 3289Lbs. And the 2009 ZR1 at 3350lbs . . . there is that BIG engine.
What I recalled is that the GS vert is 22lbs less that the GS Coupe (not the ZO6).
Craig
To Interesting
