Tpms
Old Jun 4, 2011 | 12:36 PM
Bobbyosto's Avatar
Bobbyosto
Default Tpms
Driving yesterday and on the DIC up comes "service tire monitors". Whats up? (2010 GS A6)
Old Jun 4, 2011 | 12:44 PM
RicK T's Avatar
RicK T
Is it still showing today? Do you see any tire pressure readings in the DIC when you scroll? Have you done anything to the car like disconnect the battery?
Old Jun 4, 2011 | 12:57 PM
Bobbyosto's Avatar
Bobbyosto
Have tire pressures when I scroll the DIC. Words go away after awhile, but light on the dashboard stays on. Happened 3 days ago, then off, then on again yesterday.
Old Jun 4, 2011 | 12:58 PM
Bobbyosto's Avatar
Bobbyosto
No battery disconnects
Old Jun 4, 2011 | 01:13 PM
RicK T's Avatar
RicK T
Hmmmm......no definitive answer for you. Could be a spurious communication issue with the computer/sensors, or less likely, a bad computer or sensor. Wait for more input here, especially from BEZ06 since he's the expert.
Did you notice if any of the tire pressures changed while driving? You could test the communication by driving a few minutes while noting the displayed pressures then either add or release 2-3 pounds of pressure from one or more tires to see if they register the change.
Please let us know what happens. I try to watch these threads closely to keep learning. TIA
Old Jun 4, 2011 | 02:20 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The generic fixes seem to be:
Drive over 20 mph for a few minutes
if that doesn't help:
Disconnect negative cable on battery for 20 minutes, reconnect & re-index windows
Have dealer or tire store re-match sensors and car using proper tool
or just wait for BEZO6 to chime in...
Old Jun 4, 2011 | 02:22 PM
BEZ06's Avatar
BEZ06
Do you still have your OE wheels on the car???:
If you have swapped to a new set of wheels and didn't program the new sensors into your TPMS you'll get a "Service Tire Monitor" message.
Bob
Old Jun 4, 2011 | 02:31 PM
Bobbyosto's Avatar
Bobbyosto
Bob
Bob:
Put new front tires on 2 days ago at Discount. I'm pretty sure they did the Tpms correctly. No new wheels. I did get the message a few days before all of this and then again yesterday. The original time(few days ago) car was inactive, in garage for 2 days without driving it. ???
Bob
Old Jun 4, 2011 | 04:29 PM
speedraider's Avatar
speedraider
take it to the dealer and don't worry about it.
Old Jun 4, 2011 | 04:43 PM
Duke05's Avatar
Duke05
Bob
I have the same warning, however I purchased my 2005 used with HRE 19" rims. What do I need to do to fix this warning on my display?
Can I program the sensors or do I need to take it to Chevy or tire dealer?
Thanks for your assistance with this matter
Old Jun 4, 2011 | 07:43 PM
BEZ06's Avatar
BEZ06
I guess your wheels actually have sensors in them, is that right?
If so, it sounds like they may not be properly programmed into your TPMS computer in the car. If that's the case, you're going to have to have somebody with a TPMS tool do a relearn procedure to program the tire pressure sensor ID#'s into the TPMS computer memory.
Dealers are very poor at working with something like aftermarket wheels. I would take the car to a good tire shop to get them to help you.
I had a PM from another forum member recently that has HRE's and is having problems. Here's what he asked:
....Have hre wheels that I can't get the tpms to trigger on them. The valve stem extends from the edge of the wheel to insert in the center. I'm guessing too far away for tool? Any thoughts? Thx,
2006z
Here's what I wrote back to him:
the tool needs to be within a couple inches of the tire pressure sensor in order to trigger it.
The 2005-2009 sensors require a signal from a tool to trigger them, however the 2010+ sensors can be triggered by changing air pressure - so with the newer cars you don't have the problem of getting the tool close enough.
I see in your profile that you have the earlier model year car, and I suspect that the valve stem you mention is just strictly a valve stem.
Many of the exotic aftermarket wheels require the sensors to be mounted deeper inside the wheels with either bands or brackets. Sometimes they're mounted in the OE manner with the valve stem of the sensor sticking out of a second hole on the inner side of the wheel for cosmetic purposes.
If you have the second hole on the inner portion of the wheel and see the valve stem of the sensor sticking out, you can put the antenna of the tool on the inner sidewall of the tire next to where the sensor is located.
In the case of the sensors deep inside the wheels, you need to know EXACTLY where the sensor is inside the wheel in order to get the antenna of the tool as close as possible to the sensor in order to trigger it. Normally you put the antenna of the tool on the rubber sidewall of the tire right next to the valve stem (and the sensor is connected to it and immediately inside the wheel in that location - so you know right where it is).
When the sensors are mounted deeper inside the wheels with straps/bands in the middle of the wheel, some owners have had better luck shooting through the tread to get the antenna close enough to the sensor - but, again, you need to know exactly where the sensor is in the wheel to position the antenna of the tool as close as possible.
If you have a valve stem other than the one from the sensor, there is a bracket that is available that attaches inside the wheel to the valve stem and mounts the sensor inside the wheel. If these are used, the sensors should be right inside the wheel where your valve stems go into the wheel. If they are more than a couple inches from the sidewall of the tire you may have better luck triggering them through the tread than the sidewall.
Hope all that makes sense, and good luck!!!
Bob
So.....you probably need to have the sensors programmed, and it may be tricky with your aftermarket wheels.
Bob
Old Jun 4, 2011 | 09:58 PM
BEZ06's Avatar
BEZ06
Originally Posted by Bobbyosto
Bob:
Bob
You've been driving that thing if you're putting new tires on the front already on a 2010 - and that's good!!!
I assume that Discount Tire left your original sensors in the wheels - if so, there was absolutely no need to do any programming because they were already programmed in!!
If they mixed them up and put the sensor that was in the Left Front wheel in the Right Front and vice versa, the sensors would still work fine - just the DIC readout would be wrong (i.e., if it said the Left Front had low pressure it would actually mean the Right Front).
If they did try to reprogram the sensors, if they did it wrong it might knock all of the ID#'s out of TPMS memory.
If you started getting this problem a few days before getting the new tires mounted, then I wouldn't think it had anything at all to do with that anyway.
I don't know why your sensors would be acting up, but I think the first thing I'd do is to reprogram them into the TPMS computer memory.
You're under warranty, so I would hope the dealership would just do it for free, but I've heard of many dealerships wanting to charge from $10 to $100 to do the one minute procedure!!!!
I would take it to your local Discount Tire and I'm sure they'll do it for free.
Actually, you should be able to do it yourself on a 2010. The 2005-2009 require the use of a TPMS tool to trigger the sensors during the relearn procedure, but the sensors on a 2010 and newer can be triggered by changing air pressure. Take a look at the video below and you can see how to put the car into the learn mode, then instead of using a tool at each wheel you'd just let air out of each tire to trigger each sensor, and just like in the video, you'll need to hear a honk of the horn at each wheel (double honk at Left Rear) that confirms that the sensor was triggered and sent out its data and the TPMS computer received it and logged it into memory.
So.....you can do the procedure yourself - all you'll need is an air source to pump your tires back up after you're done.
BTW, although GM changed the sensors in the 2010 and newer C6's so they will trigger with the change in air pressure method, I've read that beginning with cars built in Jan 2011 they have removed the capability to use that method, and any cars built since Jan 2011 will require the TPMS tool.
Bob
Old Jun 5, 2011 | 01:26 PM
Bobbyosto's Avatar
Bobbyosto
Bob thanks alot for the info. I know a guy with the TPMS tool so I'll ask him to run around the car with it. And about my tires, 10K on the OE GY Run flats? Horrible. Replaced with Bridgestone Potenza Pole Position RF's.
Old Jun 6, 2011 | 06:38 PM
Duke05's Avatar
Duke05
Bob - Thank you very much. This is one of the few problems that I have with my newer ride. However, after 4 weeks I'm still smiling and enjoy driving it everyday.
To Tpms
