Automatic C6 making strange noise
Old Jun 5, 2011 | 09:50 PM
BlackRocket's Avatar
BlackRocket
Default Automatic C6 making strange noise
My wife's 2007 C6 automatic makes a strange continuous noise when in Reverse or Drive. This noise is like a warbling noise coming from the accessory drive area or front of the engine. When the shifter is placed into Park or Neutral the noise disappears. Sounds like it is coming from the belt tensioner or one of the brackets is loose. The only issue is why would it go away when there is no drag on the motor; (Park or Neutral) and be constant when in Drive or Reverse. Car runs and drives perfectly otherwise. This Vette only has a little over 3,000 miles. Any suggestions on where to look would be appreciated!
Old Jun 5, 2011 | 10:09 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
don't know if water pump would make that kind of noise, but I've seen this one written up several times: harmonic balancer.
http://forums.corvetteforum.com/c6-c...te-issues.html
Old Jun 6, 2011 | 01:37 AM
Gering's Avatar
Gering
Tolero Apto Victum
Sir,
If you have to replace your harmonic balancer, you may want to check this out.
http://www.atiracing.com/products/da...ts/damserp.htm
If you have to replace your belt tensioner, you may want to check this out.
http://store.katechengines.com/bille...sioner-p2.aspx
Good luck with your Vet!
Old Jun 6, 2011 | 02:35 PM
BlackRocket
Is it safe to run the engine for a short time with the accessory belt removed? This would determine whether it is a tensioner or water pump. If the noise is still apparent then I would assume that it is the harmonic balancer. It is interesting that the noise disappears when the car is in Park, Neutral, or when you begin to drive and the RPM's increase off of idle.
Old Jun 8, 2011 | 05:06 PM
BlackRocket
Anyone have any ideas what this might be?
To Automatic C6 making strange noise
