Serious problem
Old Jun 6, 2011 | 06:38 PM
QDaddy19468's Avatar
QDaddy19468
Cruising
Default Serious problem
Hi Everyone,
Well, I'll start at the beginning. I had some long tube headers and a dyno tune performed at ECS. Car ran strong and really good. After about 200 miles or so, I started throwing some codes: Lean codes in both banks and a catalytic converter code. I sent the ECU into ECS to have the codes tuned out. I just received the ECU, installed it and when I went to start the car....nothing. It won't turn over or anything. All it does is throw a code "P0111 Intake Air Temperature Circuit Range/Performance Problem". The code doesn't seem like it would be the problem. Is there something I'm missing? Is there some sort of "reset" I should be doing since the battery has been disconnected for about 5 days? Any help is very appreciated. I'm out of ideas. Thanks.
-Quinn
Old Jun 6, 2011 | 06:42 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
I think you should hit the tech section with this broh.
Old Jun 6, 2011 | 06:47 PM
ATC399's Avatar
ATC399
Call ECS..Good luck getting her fixed...god speed
Old Jun 6, 2011 | 07:00 PM
johnodrake's Avatar
johnodrake
Moderator
Most of the time with long tube headers, the rear O2sensors will throw code. The normal way to fix the problem is to "tune the sensors out".
Old Jun 6, 2011 | 07:01 PM
beav626's Avatar
beav626
could it be something with VATS relearn... or something
Old Jun 6, 2011 | 08:17 PM
CH-Z51's Avatar
CH-Z51
From: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
I sent my ECU in for a tune and when I got it back I just reinstalled it, and started it up without any codes or other problems. I would call ECS, somethings not right.
Old Jun 6, 2011 | 08:19 PM
VET4LES's Avatar
VET4LES
ECS will take care of you.
Old Jun 6, 2011 | 08:21 PM
not08crmanymore's Avatar
not08crmanymore
Old Jul 12, 2011 | 04:54 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Originally Posted by cjlaw73
It was resolved as far as the rules on CF are concerned.
So was this minor problem, a long time ago.
To Serious problem
