Running AC w/vert top down?
Old Jun 9, 2011 | 09:59 AM
Neil Baker's Avatar
Neil Baker
Originally Posted by cclive
You can also try the trick that I learned here on the forum...you push the recirc button until the light goes on and it cuts off the warm air in the footwells and makes them significantly cooler....when its hot, the difference is amazing. This is without turning on any of the A/C system.
I always thought that when you push the recirc button it TURNS ON the AC!
Old Jun 9, 2011 | 10:25 AM
indyjack18's Avatar
indyjack18
Thanks for the input guys, I didn't think it would be a problem but wanted to double check. Full AC
Old Jun 9, 2011 | 11:12 AM
speedraider's Avatar
speedraider
Dude, if you like it , thats all that matters
Old Jun 9, 2011 | 11:32 AM
Luster's Avatar
Luster
Yup..... I'm a wuss.
In the '82, it's a different story! T-tops off at all times... 100 degrees? Yup.
Old Jun 9, 2011 | 12:02 PM
Bls8195's Avatar
Bls8195
Going to say I generally have my top down and run the AC alot, well not alot but most of the time. Seems to do just fine to me.
Old Jun 9, 2011 | 12:52 PM
CSixDude's Avatar
CSixDude
Running your AC with the top down helps reduce the effect of global warming.
Old Jun 9, 2011 | 02:32 PM
Jakeross's Avatar
Jakeross
In Texas you have to run the A/C in order to have the top down in the summer.
Old Jun 9, 2011 | 03:31 PM
speedlink's Avatar
speedlink
Originally Posted by indyjack18
Love my vert, but as you know vettes get pretty hot inside the cabin. Today was 98* and stop and go traffic was not helping. What is everybodies input on running the air with the top down. I figure even with the top up....the AC would be running constant and would have the same risk of icing the compressor (if that is even a risk) as running constant w/top down. It's hard to believe but it makes a huge difference in comfort having cold air blowing on you.
Thanks for your input
I don't understand "icing the compressor"? You can run it all the time, if you want. that's what the auto setting is for. Just set the temp. you want and you're good to go. It won't harm anything.
Old Jun 9, 2011 | 03:35 PM
ZBoater's Avatar
ZBoater
Old Jun 9, 2011 | 03:56 PM
tampatopless's Avatar
tampatopless
Originally Posted by ZBoater
I do it all the time. Helps take the edge off those toasty Florida days. Never had any issues.
Absolutely. I live in Fla. My AC -both sides - is set on 60 whether the top is up or down. I just use the fan to control it.
Otherwise, the top down in Florida in summer would be unbearable.
You know, you can always tell the tourists from the locals by the way they drive their convertibles. The locals have the top down in winter and up in summer. The tourists have the tops down in summer.
Old Jun 9, 2011 | 04:11 PM
drich2905's Avatar
drich2905
it get mighty hot here in south Georgia, so yes, sometimes I run the ac
with the top down.
sure takes a little edge off those 100 degree days
Old Jun 9, 2011 | 05:11 PM
Tin Star's Avatar
Tin Star
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
You mean this thing has a top that goes up.........guess I should have read the manual.
Old Jun 9, 2011 | 06:43 PM
  #33
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Originally Posted by BostonJoel
Do it all the time.
Also run the heat in the winter with top down.
Same here. 20 degrees in the winter top down heat on.
It was severe clear and 103 the other day, Top is always down all summer unless it's actually raining. Something about that little hint of cool air hitting you while baking. The top of my head has the best tan...
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old Jun 9, 2011 | 06:46 PM
  #34
jackhall99's Avatar
jackhall99
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
An open car with full A/C in the summer, or full heat in the winter, is great!
Old Jun 9, 2011 | 07:05 PM
  #35
shelleygraham's Avatar
shelleygraham
Works great I do it all the time. In the winter I do the reverse , the heat and heated seats. Works great !
Old Jun 9, 2011 | 07:29 PM
  #36
Ketchum's Avatar
Ketchum
100 for a while today. I came around the Athens loop top down,ac on listening to a ZZ Top disc.
Old Jun 9, 2011 | 07:34 PM
  #37
shelleygraham
U must be bald ? LOL ! Only kidding ! I agree with what you say ! Do it all the time !
To Running AC w/vert top down?
Old Jun 9, 2011 | 07:59 PM
  #38
Ketchum's Avatar
Ketchum
I'm bald! Gotta watch that sunburned head and ears! Been there done that.
Old Jun 9, 2011 | 08:10 PM
  #39
Yellow C-6's Avatar
Yellow C-6
2015 C6 of Year Finalist
Originally Posted by keyplyr
Bunch of wussies
What he said ^^^
Old Jun 9, 2011 | 08:29 PM
  #40
Ketchum's Avatar
Ketchum
Hey I drove about 1500 miles through Florida last month. 90% with the top down. I'm brown enough to prove it. I burn the heck out of my ears. Just about got my head to the miserable point.
