Rejex wheel question
Old Jun 9, 2011 | 03:16 PM
ub2slow2
Guest
Posts: n/a
Default Rejex wheel question
I've got two coats of Rejex on my chrome wheels put on a month apart and the last coat put on early May. Car never see's rain and I don't wash the wheels since they don't get very dirty and just dust them with a soft cloth every other week.
Question is, do I need to put on any more Rejex or should those two coats get me through till I put the car up for the winter? I know it says it lasts 6 months and the shine is very good still.
Just curious to hear you Rejex/wheel experts out there.
Old Jun 9, 2011 | 03:22 PM
keyplyr's Avatar
keyplyr
Originally Posted by ub2slow2
...I know it says it lasts 6 months and the shine is very good...
I think you answered your own question.
When all else fails, follow (believe) the instructions
Old Jun 9, 2011 | 03:28 PM
ub2slow2
Guest
Posts: n/a
yeah yeah lol
I've only just started dealing with Rejex though and figured some of you guys have been using it for years and might have real world experiences that may or may not differ from what the bottle claims
Old Jun 9, 2011 | 03:55 PM
speedlink's Avatar
speedlink
yeah yeah lol
As was said, just follow the instructions. If you want more protection, put on another coat. It may help a little.
Old Jun 9, 2011 | 05:33 PM
easyrider13's Avatar
easyrider13
I pull off my wheels every three months or so to clean the barrels and to scrub the inside sidewalls. At that time I re-apply rejex to the wheels.
Old Jun 9, 2011 | 05:57 PM
ub2slow2
Guest
Posts: n/a
ok thanks. Sounds like I can make these 2 coats last until the end of the season or until I get caught in rain and have to clean them real good.
Old Jun 9, 2011 | 06:04 PM
Dif's Avatar
Dif
I've been using Rejex on my wheels ( and Paint ) for a couple years now and even after a drive in the rain, they just wipe clean.
I'll put an extra coat on from time time just for good measure.
But Rejex last a Looooong time before actually needing another coat
Old Jun 9, 2011 | 06:14 PM
PeterSG's Avatar
PeterSG
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-‘19-'20
Default My Experience
I have an '07 with OEM chrome wheels and drive the car a few thousand miles during the winter months in Chicago snow and salt.
For the first three winters I used either Meguiar's Nano wax or their cleaner wax. At the end of each of these winters the wheels had a stained appearance and required a lot of elbow grease each spring to thoroughly remove that irregular, dark appearance.
Last October I applied Rejex to each wheel. Over the winter the wheels never looked more than dirty. There was no stained appearance. This spring the only cleaning needed was my regular wash! All dirt floated away with no elbow grease.
After four Chicago winters the chrome wheels look brand new.
Last week I applied one more coat of Rejex to the wheels -- and to the entire car.
Old Jun 9, 2011 | 08:25 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Two coats of Rejex on my chrome wheels has held up for about a year.
Don't drive in much rain but they get a good wash with a wheel brush (including the barrels) with every car wash.
Excellent product for this application IMHO.
Old Jun 9, 2011 | 08:26 PM
ub2slow2
Guest
Posts: n/a
Thanks for the great info guys
Old Jun 9, 2011 | 11:28 PM
Le Mans Z06's Avatar
Le Mans Z06
If I wash my wheels with soapy water and a clean towel will it strip the rejex coat I have on it? Or will it be fine?
Old Jun 10, 2011 | 12:01 AM
Knob Jockey
You must apply Rejex to an absolutely spotless wheel surface that has nothing whatsoever left on it.
The Rejex "fuses" with the surface and should survive months of washings.
Old Jun 10, 2011 | 12:34 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
It should be fine. I've used Rejex on my car since day 1. Each year I wash it with Dawn, clay it, wash it again with Dawn and then Rejex it (including the chrome wheels). The Dawn and clay doesn't even get rid of the existing Rejex so I don't think you have anything to worry about.
Old Jun 10, 2011 | 11:41 AM
Craig P's Avatar
Craig P
I didn't think you could "layer" Rejex because it has a small amount of solvent in it for cleaning and therefore just desolves the layer you are putting it over.
Old Jun 10, 2011 | 12:25 PM
ub2slow2
Guest
Posts: n/a
No, the more layers of Rejex the better. You can't layer it on top of wax is maybe what you've heard.
Old Jun 10, 2011 | 03:39 PM
stoessjc's Avatar
stoessjc
Lean my chrome wheels with apply cider vinegar, then Rejex.
Old Jun 10, 2011 | 05:59 PM
Dif's Avatar
Dif
From what I've seen .. about the only way to remove Rejex is with a paint polish or chemical based paint cleaner.
http://www.autogeekonline.net/forum/...t-sealant.html
When removed the Rejex before putting my clear bra on I used Sem Solve ..
http://www.semproducts.com/Catalog.asp?prod=81
Old Jun 10, 2011 | 07:12 PM
TLK's Avatar
TLK
St. Jude Donor '09-'11
It doesn't last 6 months. I did this last summer and occasional washes strips it pretty fast. Without washing, it just seems to "burn off" after a while from the summer ambient/engine/brake heat. Rain also takes it off as well. In my experience, the best part of the effect lasts maybe 2 months in good weather and then it needs to be done again. Probably every month is best, but until I get a lift it's too much hassle to do often.
Old Jun 10, 2011 | 09:08 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Did you have something else on your paint before using Rejex? I ask because I've used only Rejex and nothing seems to take it off.
I will agree that it not quite as shiny or slick after a couple of months but in my case washing or rain confirms that it's definitely still there.
To Rejex wheel question
