930BT splash screen
I am trying to put a C6 LOGO on my splash screen that I obtained from another thread here..
I thought it would be as simple as put pic on micro SD CARD AND INSERT CARD INTO SLOT ON 930BT???
I put the card in the head unit and I cant find out how to access pics??
when I go into the splash screen settings it says choose from SD card. When I touch that it says put pictures in folder???
I am confused.
I am confused.
Might want to try posting this in the audio section of the forum. I'm sure you'll get the help you're looking for over there. If not, try contacting Dennis at Double D Mods, C5 BearsFan on CF (a forum vendor). He sells the Pioneer and Kenwood units and will know how to advise you.
See page 165 in the Operation Manual. In a nutshell, you need to create a folder called "Pictures" on the top most directory on your SD card. Then load your pictures in this directory on the card. Once you have them in this directory, insert the card into the 930BT and go to the System Settings to load the pic you want. Hope this helps.
