Can C6 headlight lenses be polished?
I had Ultrashield film applied to the front end and headlight lenses on my 2004 RX-8 (bought in summer 2003/traded it in when I got my 2011 GS) and all the covered body panels plus the headlight lenses looked as good as the day I bought it when I traded it in last June 2012. The previous owner of the GS had the full 3M film kit applied, including the headlights, so they are already covered. I just wash & wax the film like the rest of the car and don't worry about bugs/chips/etc as the film prevents those from affecting the actual plastic of the lenses.
Curious if this can be for the red tail light lenses, as well? Evidently the dealerships own body shop, while in to repair a "bump" on the rear, removed them and scratched every tail light slightly. Bozo's didn't put them down on anything that would protect them obviously. Granted, no one would even notice (except me and most here) but . . . .
I have a 2005 C6 that had severe crazing of both front headlight lens. I thought it was on the inside , TOO. But before I removed and replaced the lens I did this with great success : purchased a 3M headlight kit to get drill adapter and SOME sanding disc, purchased a box of 320 grit wet sanding disc [ more than I needed in the box ] . TAPED OFF EDGES OF LENS AND COVERED CAR WITH 2- 50 GALLON TRASH BAGS WITH HOLES CUT AND TAPED TO LENS. REPAIR : hand sanded WITH 320. then used a portable drill with pad attached 320 grit-- moving over the entire lens till ALL !!!!!!!!! OF THE SPOTS WERE REMOVED--- IT REALLY TOOK A LOT MORE THAN I EXPECTED. CAN CHECK BY WIPING OFF WITH BOTH A WET AND DRY TOWEL AND LOOKING CAREFULLY FOR ANY SPOTS!!!! THEN 320 WET SANDED . THEN PROGRESSED 500 800 1000 2000 DRY THEN WET SANDING. WET SANDED WITH 3000- wiped clean with alcohol then SPRAYED RUSTOLEUM 2X CLEAR--- 4 TO 6 COATS [ ONE CAN / LENS] --- ALLOW TO DRY FOR 24 - 48 HOURS-- CLOUDYNESS CLEARS AS IT DRYS--- THEN: WET SAND WITH 2000 TO REMOVE ALL THE ORANGE PEAL then wet sanded with 3000-- BUFF WITH ENCLOSED 3M RUBBING CPD, THEN BUFF/POLISH WITH LIGHT RUBBING CPD TILL CLEAR / SMOOTH AND GLOSSY . ALLOW TO DRY FOR 5-7 DAYS --- 95% +/_ improved -- I thought they looked great-- clear coat has a UV protection IN THE CLEAR COAT !!! HAD TO RECHARGE BATTERY MANY TIMES !! VARIABLE SPEED ELECTRIC DRILL ON LOWER SPEED WOULD HAVE BEEN GREAT.
SteveDoten@ARH (05-02-2016)
I realize that if I were to use a headlight retsoration kit that it would basically eliminate the clear coat that covers the headlight lens. I have purchased the pre-cut (generic) static film headlights cover product with the intent that that would replace the need for UV coating on the lens as my c6 is in the garage 95% of the time all year.
I have the same problem with the foglights.
By the way, not completely my fault as I bought my 07 "pre-owned" with 49k on the odometer. Ive put 3k on it in the past year.
any help would be appreciated!
montyred
montyred
Premium Supporting Vendor
NSF
****EDIT**** I just continued to read the comments and see someone else posted that they did something almost identical to the process I did so take this for what its worth :p
My headlights on my car were very hazed and faded, along with all the scratches and such. I had purchased a pair of new lenses from RLSebring and although in the grand scheme of things $400 wasnt that much, but being on a budget like myself (21 years old) I decided I wanted to try and restore the current lenses before I swapped out for the new ones... I had some time last weekend and nothing to lose if the current lenses didnt come out good. I originally thought it was on the inside of the lens so there was nothing I could do but upon further ispection realized that was not the case and it was on the OUTSIDE.
I started out by wet sanding with 600 grit, then 1000, and then 2000. I then clear coated the lenses with rust-oleum UV resistant spray paint. Let them dry overnight and then wet sanded the clear coat with 2000 grit sandpaper to get rid of any orange peel. I finished off by polishing and waxing the lenses.
They obviously arent 110% but they look 1000 times better then they did before, and all with $10 in materials I sold the replacement lenses the next day and that put 400 bucks back in my pocket to spend on a different mod
I wish I had taken close up shots of the lenses before, so you could get a better idea of how poor of condition they were in but this is the best I've got. This is what they looked like the day I picked the car up.
mbsnmisc (03-20-2017)
