Loud click when breaking
Old Jun 20, 2011 | 05:23 AM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Default Loud click when breaking
Hey everyone, I have this really annoying click sound every time my 06 auto comes to a near stop. It does it almost every time I hit the breaks, slowing to around 8mph. Its a click like a snapping carrot and seems to come from the center of the car, more towards the rear.
Its not associated with the breaks because it will still do it if I coast and slow to around 8-10mph.
Just wonding if someone else expierienced this with a solution before I take it to the stealership, its driving me craaaazy
Old Jun 20, 2011 | 08:23 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would be under it looking for anything coming lose. There are lots of possibilities
Old Jun 20, 2011 | 08:28 AM
Ketchum's Avatar
Ketchum
If its not affected by the 'BRAKES" maybe a u joint is trying to 'break'
Old Jun 20, 2011 | 09:37 AM
soulcoaxing's Avatar
soulcoaxing
Acct suspended by request 21 Sept 2011
Old Jun 20, 2011 | 09:48 AM
b4i4getit's Avatar
b4i4getit
Are you sure its not the brake relay you are hearing ?
Old Jun 20, 2011 | 10:05 AM
dbunn's Avatar
dbunn
Agreed. I hear the relay coming ffrom the vicinity of the fuse box area anytime I step on the brake. I assume it is what releases the locking mechanism for the auto shifter. Might be wrong though.
Old Jun 20, 2011 | 11:15 AM
Vettin08's Avatar
Vettin08
99% sure it's the brake relay in the fuse box under the passenger footwell. There was a TSB for it a few years ago, but I don't remember '06s being affected by it. It could be that yours just went bad. No biggie, take it to the dealer an have them replace it, it's cheap.
Old Jun 20, 2011 | 03:52 PM
b4i4getit's Avatar
b4i4getit
The loud brake relay is an ongoing problem. You will find posts saying to get them to change the relay however the noise may still be there. This problem is even on current 2011 models and will probably surface on 2012 models as well. I think GM changed the supplier of the relay a few years back and depending on what your dealer has in stock the problem will be solved or will remain the same. Just get used to it and turn the radio up.
Old Jun 20, 2011 | 04:27 PM
Nick996's Avatar
Nick996
Find the relay and wrap it in Dynamat.
Old Jun 20, 2011 | 04:36 PM
ub2slow2
Guest
Posts: n/a
I wondered what that was as I hear it as well when it's quiet and it happens every time I touch the brake. Wasn't worried about it just thought it was weird.
Old Jun 20, 2011 | 04:41 PM
torquetube's Avatar
torquetube
It's not the brake light relay. The OP says right in his post "Its not associated with the breaks because it will still do it if I coast and slow to around 8-10mph."
Does it happen when the auto gearbox downshifts?
Old Jun 20, 2011 | 05:00 PM
Gman in NC's Avatar
Gman in NC
If it doesn't do it by pushing on the break but still does it at 8mph it might be something happeningint when the transmission goes in first. Try manually putting it into first or second and doing the same thing.
Old Jun 22, 2011 | 06:34 AM
LMB 4 ME's Avatar
LMB 4 ME
Thanks everyone for the possible solutions. Ill try GMANS transmission test and see what happens.
Its def not the relay because it comes from under the car and passangers agree its an area behind our seats. Plus the noise isnt associated with the breaks.
Gotta be the transmission GULP!
BTW, I couldnt find anything loose under the car.
Old Jun 22, 2011 | 07:03 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
Mines doing the same thing. I'm taking it to hp sales to check it out.
Old Jun 22, 2011 | 07:49 AM
dgrant3830's Avatar
dgrant3830
I'd be looking at sway bars, end-links and etc...
Old Jun 22, 2011 | 10:12 AM
torquetube's Avatar
torquetube
If you keep the gearbox in 1st and drive at, say, 4500rpm, and then let off the gas abruptly, does it make the sharp snap sound? Then, if you get back on the gas (still in 1st) somewhat hard, does it make the sound again?
If it does, it sounds like the splined interface between the half-shafts and the rear wheel hubs is dry and needs to be greased.
Old Jul 1, 2011 | 06:38 AM
LMB 4 ME's Avatar
LMB 4 ME
TT, I will try your suggestion today. Heres what I learned from last drive
1-Does it sometimes when coasting down to around 4-8mph
2-Does it sometimes when applying the brakes and the car hits 4-8mph
3-does it in all modes. Sport, regular auto or using the paddles manually
4-Tranny goes in 1st gear around 8-10 so its not a 1st gear thing (and hopefully not the tranny!)
Sometimes its a single loud POP and sometimes its a quick double pop.
To Loud click when breaking
Old Jul 1, 2011 | 06:42 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
When I spoke to hp sales he said there was a GM Service bulletin about this. take it to Jeremy or wait for me next week and I will let you know.
Old Jul 1, 2011 | 08:07 AM
agrumpyguy's Avatar
agrumpyguy
Check the rear axle nut bolts.there is a TSB about this .they loosen and ned to be retorqued causing clicking noise at low speed
Old Jul 1, 2011 | 08:45 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
Exactly what I was told, but HP sales said that they have replacement bolts in stock because of it. He just needs to hear the car in person and see if that is indeed the problem. I will know more in 2 weeks.
