Ls3
Old Jun 20, 2011 | 11:28 PM
rwarhol's Avatar
rwarhol
Default Ls3
How much horsepower does a stock LS3 put out at the crank.
Old Jun 20, 2011 | 11:32 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
430 HP; 436 HP with the NPP dual-mode (butterfly valve) exhaust.
Old Jun 21, 2011 | 12:10 AM
Vette_DD's Avatar
Vette_DD
I thought it was 436 HP only if the dual mode exhaust was in the "wild" setting.
Old Jun 21, 2011 | 12:28 AM
boraxman's Avatar
boraxman
Remember on a unmodded NPP the flaps open at around 3500 RPM....LS3 are 436 with NPP in stock, unmodded form.
Old Jun 21, 2011 | 12:30 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
What he said...........
Old Jun 21, 2011 | 08:09 AM
mneblett's Avatar
mneblett
Well, yeah.
HP ratings are the max HP output. 436 HP is the max HP output. That occurs when the valves are open, peak power happening well over 3500 rpm and at full throttle. Below 3500 when the NPP valves are closed, I doubt either motor is making over 250 HP. So what was posted is accurate.
Old Jun 21, 2011 | 10:47 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Since HP is based on torque & RPM.....that is a definite DUH!
Old Jun 21, 2011 | 10:48 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
To Ls3
