a/c problems
Old Jun 27, 2011 | 02:46 PM
silverbullet05's Avatar
silverbullet05
8th Gear
Default a/c problems
I have an 05 and after being in the car a while the a/c will become hot.
i just hit the switch and it will take a few min and it will start getting cold again.can any one help
Old Jun 27, 2011 | 02:57 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
Compressor's taking a dump. Mine is doing it as well.
Old Jun 27, 2011 | 03:02 PM
silverbullet05
8th Gear
thanks I will hate to see the cost in a Compressor
Old Jun 27, 2011 | 03:06 PM
TNTC4VETTE's Avatar
TNTC4VETTE
You can find compressors for decent prices at the supporting vendors. Install is what gets you.
Old Jun 27, 2011 | 04:47 PM
MDPD23's Avatar
MDPD23
I had an'05 and at 115,000 miles I had to replace the A/C radiator. Dirt debris completely clogged it up.
Old Jun 27, 2011 | 05:26 PM
silverbullet05
8th Gear
thanks that is about the same mileage
Old Jun 29, 2011 | 01:54 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Are you going to go to the dealership for a second opinion at all? Please keep us updated on what happens with this. I want to make sure it gets fixed.
Thanks,
Laura
GM Customer Service
Old Jul 8, 2011 | 03:43 PM
silverbullet05
8th Gear
Thanks,
Laura
GM Customer Service
not sure if i will take it to a dealer cause i am out of warranty
there is no good will on things like that are there
Old Jul 8, 2011 | 04:37 PM
Hoonose's Avatar
Hoonose
Early '05's had an A/C overfill problem. Too much factory installed 'freon'. Mine would cycle on and off when over 120 degrees. Which is not uncommon here. There was a TSB to remove 0.1 lb as I recall, but you could try to release about 2 pfhhhhts of 'freon' manually yourself and see if the condition improves. It doesn't sound like you've got much to lose anyway.
My compressor started making funny noises about 2 summers ago and was replaced on my extended warranty. About $800 as I recall.
Old Jul 8, 2011 | 04:50 PM
saplumr's Avatar
saplumr
Technically "Freon" is a manufactures name. However the 05 cars did have a factory refrigerant overcharge which didn't affect my car until the blower was put on 6 months after new. Servicing dealer evacuated and recharged system to correct weight.
Old Jul 11, 2011 | 10:27 AM
Chevy Cust Svc
I understand. Since the dealers have the final say on goodwill and those sorts of policies I can’t promise that they’d cover anything. I apologize.
Thanks,
Laura
GM Customer Service
To a/c problems
