C6 Navigation Up-Grade??
The part numbers I see on eBay are 15292581, 15263014 and 152333090... not sure what they mean but I'm looking for a AM/FM/XM/NAV unit plus I think I need an additional antenna and the NAV CD/DVD with the mapping info...
Any suggestions would be grate...
Boomer
Boomer
We can set you up with as close to plug n play as possible on aftermarket
For 839.99 we can set you up with the Pioneer x930bt
radio
harness
metra dash kit
antenna adapter
we can prewire this all but 2 wires that would need to be connected
1- orange white wire from radio to gray wire on traction control.this is for the night time dimming to work correctly
1- if wanting the option of the bypass to allow for adjusting nav and (not recommended) watching movies while driving. I can perform the byapss. You would just need to make final crimp and connection which I can not do.
install is as simple as putting in a stock unit.
used factory NAV is prob going to run you around 600.00 or so on average
your into aftermarket for a little more but gaining many more features including DVD and BT plus th eipod features by adding the optional ipod cable.
We can also add a backup camera as well to this unit.
to add a backup camera to the stock unit you would need the lockpick which would add another 350.00 or so to the cost of the stock unit.
many options and we are there to help you with tech support on install as well.
call me if you want more info and I can help you out.
I had mine installed by a car stero shop and he (doublemods) helped me help them (the installer) to get mine to work correctly...the unit would reboot when using ONstar.
Thanks for the kinds words and again for your business
In any case, you would be much better served opting for a Kenwood or Pioneer system - many, many more features and much more current than the very dated factory system. I have a Kenwood DNX6960 with Garmin based nav, iPOD capability, bluetooth for my cell phone, Sirius satellite radio and a back-up camera purchased from Dennis at Double D Mods; all for less than the cost of a factory system. I have been delighted with it.
Who performed install of your system ? Any PIcs?
. If you have a HUD - it integrates with that as well. Aftermarket units do not.
