Convertible top "beating"
Old Jul 1, 2011 | 12:09 PM
lamboguy's Avatar
lamboguy
Default Convertible top "beating"
My 2009 C6 convertible top "beats" a bit from the rear around 70mph and above. A low beat, almost like the flapping of a sail or flag.
Is this normal?
Seems to have a lot to do with side winds. Sometimes it won't beat at all at those speeds, but typically it does, and I look around and the bushes and trees are swaying from some sort of wind. (Living in SF we get a lot of wind from time to time)
It's fine the way it is -- I've had MUCH worse with other cars.
But just wondering if there isn't supposed to be any beating at all. If that's the case, I need to get my top fixed/adjusted.
Thanks!
Fred
Old Jul 1, 2011 | 12:19 PM
RJRSW's Avatar
RJRSW
Yes it is normal.
I here a similar noise on the freeway with my 2007 convert when there is a strong cross wind. It is barely audible but can hear it.
Never had that in a similar situation with my C5 convert so must have to do with the cars aerodynamic differences.
Old Jul 1, 2011 | 12:22 PM
indyjack18's Avatar
indyjack18
I'm on my second vert, neither made such a noise. My '09 was dead silent, my '11 GS has lots of road noise & wind noise. I only have it up in the rain so it hasn't bugged me enough to fix.
Your flapping/beating noise sounds like loose material that should be secured. Hope it's fast, easy fix
Old Jul 1, 2011 | 12:27 PM
lamboguy's Avatar
lamboguy
Makes sense that it is a bit "loose" because I have to hold the window up a tad when raising or lowering the top, so the toneau cover doesn't hit.
Is "tightening the convertible top" something that is actually done? There is a good factory dealer not too far from here that does a lot of vette work. Think they would be able to actually fix this problem? Or is it one of those "well, leave it here and we'll look at it, for $150/hour" sort of things...?
Old Jul 1, 2011 | 12:36 PM
StanNH's Avatar
StanNH
No such noise from mine; at high speeds or in high cross winds. Sounds like it might need an adjustment.
Old Jul 1, 2011 | 01:04 PM
keyplyr's Avatar
keyplyr
I drive very very fast through the desert and never a bit of noise from my '05 top.
Old Jul 1, 2011 | 01:13 PM
RJRSW's Avatar
RJRSW
My top is very tight like a drum and no areas are loose at all. Maybe I hear it because of it being tight like a actual drum.
I think that I notice it most when I'm in high speed freeway traffic around other vehicles so might have something to do with buffeting wind coming off the other vehicle and hitting the top.
Kenny94945's Avatar
Kenny94945
05...ditto I have not noticed this noise/ beating sound.
I guess you need to give your top a look over for alignments, clips, sewing threads etc. to see if something is wrong.
Maybe it is normal (?) I just never noticed a noise.
Old Jul 1, 2011 | 01:19 PM
RJRSW's Avatar
RJRSW
Only 3,000 miles on my car and the top is literally like brand new.
If the radio is at normal listening level I do not really hear it but if the radio is turned down low I can detect it then. It really is not a problem and like I said you really have to be listening for it.
Old Jul 1, 2011 | 01:47 PM
lamboguy's Avatar
lamboguy
Mine is fairly subtle as well. But being a "musician" I tend to hear things...like sublte beating tops.
I'm almost thinking of going to the dealer and asking their top guy to take a test drive with me. Just because it costs nothing to think these things.
Old Jul 1, 2011 | 02:18 PM
Thrash's Avatar
Thrash
Take it to your dealer, sounds like something needs to be tightened, or a bit of upholstery work maybe. My '09 is at the dealer now getting the vert liner fixed (it had pulled away from the frame on the upper left, above the drivers seat by about 1.5") ...
Old Jul 1, 2011 | 02:31 PM
lamboguy's Avatar
lamboguy
Thrash -- yours is a dead ringer for mine. Is it a ZHZ? Mine is.
Thanks for the info...I'm starting to think dealer is the answer.
Old Jul 1, 2011 | 05:19 PM
JJC5's Avatar
JJC5
The fabric can be tightened up but my experience with a prior C6 convertible will tell you that no dealership knew how to do it. I ended up taking mine to a custom upholstery shop that stretched it front to back. If done too much, the sides may wrinkle. To do the sides is a lot of work.
Old Jul 1, 2011 | 05:55 PM
lamboguy's Avatar
lamboguy
I hear ya. The dealer would have to convince me they pretty much can guarantee me they can do this properly or I wouldn't trust them. It looks like a black art to me...
Old Jul 1, 2011 | 06:00 PM
JJC5's Avatar
JJC5
My vert was Velocity Yellow with Ebony as well; nice color package too!
Old Jul 1, 2011 | 10:04 PM
Eritosthenes's Avatar
Eritosthenes
I think my '07 vert may make a similar sound going through one of those $1 hurricane blow dryers. I don't think I've ever heard it on the road.
Old Jul 1, 2011 | 10:06 PM
shelleygraham's Avatar
shelleygraham
I don't have any noise from mine either .
To Convertible top "beating"
Old Jul 1, 2011 | 11:03 PM
lamboguy's Avatar
lamboguy
Is that with your doors up or down?
Ok...well thanks. I think I need to do something.
Old Jul 1, 2011 | 11:09 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Mine makes some flapping noise, but not too bad.
Old Jul 1, 2011 | 11:10 PM
carjo's Avatar
carjo
The only annoying noise I hear in my '09 vert is when I am doing more than the posted speed limit, and comes from the passenger seat.
Only kidding honey.
