Considering an '08 Vert
Old Jul 6, 2011 | 01:45 PM
bierbelly's Avatar
bierbelly
Default Considering an '08 Vert
Any known outstanding problems with this year? I'm a C5 owner.
Old Jul 6, 2011 | 01:50 PM
tjl5709's Avatar
tjl5709
Nope, great car. The LS3 rocks! There is a known issue with the inside headliner. Do a search for it. There is a TSB.
Old Jul 6, 2011 | 01:51 PM
dvilin's Avatar
dvilin
Bought my 2008 Coupe new and have not had a single problem in a bit more than 3 years of ownership. Also not aware of any known problems.
Old Jul 6, 2011 | 01:52 PM
bierbelly's Avatar
bierbelly
Thanks for the feedback guys.
Old Jul 6, 2011 | 02:10 PM
IDSRVIT's Avatar
IDSRVIT
No issues with my 08 vert
Old Jul 6, 2011 | 02:17 PM
ATC's Avatar
ATC
I have an 08 coupe with no issues since new in 8/07.
I am ready for some softer, quieter tires though!
Old Jul 6, 2011 | 02:22 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
I'm also a C5 owner. And an '08 'vert owner.
The only "common" issues I've seen are the occassional roof interior tear issue (not an '08-only issue?? not sure), airbag lights on the IP due to problems with the under-seat connectors for the airbag and/or the seatbelt pretensioner explosive device (not an '08-only issue), and the swaybar end links wearing too quickly and causing suspension clacks/clunks (not an '08-only issue).
My own car had the DVD drive for the navigation map DVD crap out.
Other than that, my '08 is doing quite well, thank you, at nearly 26K miles.
Old Jul 6, 2011 | 02:47 PM
c6miller's Avatar
c6miller
I have an 08 JSB 3LT vert, great car, only issues were the "A" pillar trim replaced on both interior sides and driver exterior trim. Also the top liner already mentioned. Put on Michelin PS2 sport and the ride is wonderful.
Old Jul 6, 2011 | 02:50 PM
mneblett's Avatar
mneblett
+1
Old Jul 6, 2011 | 02:51 PM
bierbelly's Avatar
bierbelly
Precisely what I'm looking at, with the A6 tranny. What happens to the trim/top liner? Since this will be likely out of warranty, it would be good to know.
Old Jul 6, 2011 | 03:12 PM
KevinJax's Avatar
KevinJax
Make sure that the rear end fluid has been updated to the new one that GM recommended. I had mine done under warrenty (barely). The original fluid caused a low pitched grinding noise when going at low speeds and turning. Now no more noise.
Old Jul 6, 2011 | 03:34 PM
Illinois427's Avatar
Illinois427
In addition to the comments everyone else is making, I would say be sure to cycle the top a few times to make sure it functions properly. The power tops have a bunch of mechanical operations that are controlled by micro switches in the top. If it functions correctly then all should be good with them.
Old Jul 6, 2011 | 03:36 PM
Thrash's Avatar
Thrash
If you go with a '09 you'll get Bluetooth and a couple of other upgrades, and just 2 yrs old. But a deal is a deal, good luck ...
Old Jul 6, 2011 | 03:43 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
just remember that , to an extent, the C6 is a far more "electrical/computer controlled" car than your C5. that means things can, and will go wrong such as those top sensors. or a gas pedal sensor (mine), or low tech stuff like a sweating/leaking oil pan area (can be gasket, seal or porous pan, mine), rear diff fluid swap, etc. some of it may (stress: may) be inherent in the design or production since outside vendors are used, or it could just be a premature failure. regardless, it can happen at any time.
Old Jul 6, 2011 | 03:50 PM
boraxman's Avatar
boraxman
Do it!
Old Jul 6, 2011 | 03:55 PM
bierbelly's Avatar
bierbelly
Just got a message from the dealer that they've "just sold that car".
Old Jul 6, 2011 | 03:58 PM
kygakman's Avatar
kygakman
Sideways Saturday
I really enjoy my 2008 Crystal Red Vert, I like the Bluetooth on the 2011CTS-V I just purchased, and while it would be nice to have on the Vette, it wouldn't be a deal breaker for me on the 2008.
To Considering an '08 Vert
Old Jul 6, 2011 | 04:18 PM
MONTVALEGOLF's Avatar
MONTVALEGOLF
St. Jude Donor '12, '15
sent you an email.
Mike
Old Jul 6, 2011 | 04:20 PM
bierbelly's Avatar
bierbelly
Originally Posted by MONTVALEGOLF
sent you an email.
Mike
Who, me?
Old Jul 6, 2011 | 04:29 PM
edloke's Avatar
edloke
Only issue I ever had with 08 vert was battery. Great car.
