Belt problems??
Old Jul 8, 2011 | 05:29 PM
Steven Crockett's Avatar
Steven Crockett
Default Belt problems??
Bought A 2008 C6 coupe with 10000 miles. Shortly after, squealing noise in engine. Corvette garage replaced serp. belt. Ok for awhile and then noise in engine area, sounds like marble/bearing rolling around. Belt keeps getting torn and partly ripped right off. Gone through 3 belts. Anyone have any idea. It doesn't do it all the time. (Tension pulley?)
Old Jul 8, 2011 | 05:31 PM
R&L's C6's Avatar
R&L's C6
Is the harmonic balancer running straight and true?
Old Jul 8, 2011 | 05:36 PM
Larry/car's Avatar
Larry/car
:Something is definitely out of alignment, the harmonic balancer would be my first guess. Your belt should last 100,000 miles.
Old Jul 8, 2011 | 05:39 PM
jltcat's Avatar
jltcat
harmonic balancer issue maybe check it with the engine idling and see if you have any wobble on the "crankshafts pulley" You may have a little bit but too much is bad I'd say by eye more than 1/16 of an inch wobble movement isnt good. In a perfect world no wobble is best. I'd check that first. Also other possibility is crank pulley has backed the bolt out of the crank but you shouldnt have that issue with a 08.
Old Jul 8, 2011 | 05:57 PM
Steven Crockett
Thanks for the info. Will have my mechanic check these suggestions on Monday. You guys are great.
Old Jul 8, 2011 | 06:12 PM
kcust62's Avatar
kcust62
If you're running the A6 Automatic, you most likely have a decoupler pulley on the alternator. It's designed to keep the belt from slipping off during heavy accel/decel, so, check to make sure it is functioning properly. Pull the belt and spin the alt pulley clockwise, It should be effortless. Counter-clockwise, it should have a slight drag without grinding. Just another thought to what others have said. Good luck!
Old Jul 8, 2011 | 06:25 PM
vetteright's Avatar
vetteright
Just a thought, but if you don't have any engine mods, I would think that this situation should be covered by your powertrain warranty; it's good for 5 years or 100,000 miles. I'd get a Chevy dealer with a Corvette tech involved.
To Belt problems??
