A/C Compressor Bearing
Old Jul 10, 2011 | 10:29 AM
scot's Avatar
scot
Default A/C Compressor Bearing
I've been reading to try and find the cause of a grinding noise in my 2005 corvette coupe and the only thing that seems to match is the bearing in my ac compressor. If the A/C is turned on there will a vibration I can feel around 1500-1700rpm when pushing in the clutch. There is also a sound as well. Turn off the A/C and everything is fine.
Two posts seem to point to a bearing for the compressor.
Is this bearing replaceable or is it integral to the compressor? If so, anyone know a part number and maybe a procedure? I don't see anything on the web showing a replaceable bearing, but that doesn't mean it can't be done.
Any help would be very appreciated.
(BTW, a/c works great. vehicle stays nice and cold, clutch seems to engage/disengage etc.)
Old Jul 10, 2011 | 10:59 AM
tim414's Avatar
tim414
St. Jude Donor '12
I think the bearings in a/c compressor are machine pressed and likely you will have to replace it w/rebuilt one. It could be clutch in compressor as well. Although at that rpm the clutch not likely I think....I'm NO expert. Someone else will chime I'm sure.....
Old Jul 10, 2011 | 11:03 AM
VET4LES's Avatar
VET4LES
Sounds like you need a new compressor. I have not heard of anyone rebuilding them.
Old Jul 10, 2011 | 01:06 PM
scot's Avatar
scot
Darn, I was hoping that wasn't the answer. Looks like I'll be rolling the windows down a lot this summer
Anyone have a list of parts I'll need to get for someone to do this job? I'm guessing this will need to have some refrigerant work done, so i'll be letting an expert do the work and just provide the parts.
Old Dec 23, 2013 | 07:49 AM
Ahmer's Avatar
Ahmer
Resurrect this thread? I have the same problem now.
Old Dec 23, 2013 | 10:23 AM
Racer86's Avatar
Racer86
IF,,,,, you want to replace any ball or roller bearing, you measure the outer diameter, the width, and the hole diameter, usually in MM. Must be accurate measurement with dial or digital calipers. When you know the size and details about the bearing, ( sealed sides, ceramic, stainless, mount style, etc ) any bearing supplier can supply it to you.
But, as stated above, replace the complete unit, if it has been vibrating, other internal damage is possible.
Old Dec 23, 2013 | 10:58 AM
crAzy's Avatar
crAzy
I had this prob. Warranty replaced compressor and condensor. $1800 repair.
Old Dec 23, 2013 | 03:21 PM
Ahmer's Avatar
Ahmer
$1800????
Dang!
Old Dec 23, 2013 | 03:58 PM
crAzy's Avatar
crAzy
Originally Posted by Ahmer
$1800????
Dang!
Took it to a reputable vette mechanic. I only paid $100 for my deductible.
Old Aug 19, 2014 | 11:01 AM
KOTYKB's Avatar
KOTYKB
I'm also having this same issue, is it necessary to replace the compressor and condenser or just the compressor?
Old Aug 19, 2014 | 02:55 PM
crAzy's Avatar
crAzy
I was told it is best to replace both at the same time.
Old Aug 19, 2014 | 03:15 PM
KOTYKB's Avatar
KOTYKB
Wonderful, it sounds like a cheap fix
Old Oct 28, 2014 | 03:30 PM
KOTYKB's Avatar
KOTYKB
I'm still having this issue and it's about time I fix it. Why did your mechanic recommend to replace the AC condenser too? I was only going to replace the AC compressor since the bearing is going bad and leading to the drive train vibration.
Old Oct 28, 2014 | 07:03 PM
truckplay's Avatar
truckplay
yes the bearing can be replaced. all you need is a press. the bearing needs to be pressed out then you can go to a parts store and match up the number. unless you are really bored, just buy a new compressor.
as far as why a mechanic told you a condenser is needed, that is only to pad the repair order unless the compressor has failed and metal has gone into the system. if that happened the entire system needs to be opened up and the lines need to be flushed out. the condenser can not be flushed because the veins are so small that they trap the debris but it can not be flushed. you will also be required to change the accumulator.
as long as the system still cools and you only have a clutch issue, change the compressor (buy a good one) and call it a day. any monkey can change it in 2 hours. the easiest way is to pull the coolant hose and t-stat and slide it up and out.
Old Nov 20, 2014 | 02:57 PM
KOTYKB's Avatar
KOTYKB
Anybody else having this issue?
Old Nov 20, 2014 | 07:01 PM
hrt vlv's Avatar
hrt vlv
When you replace the compressor you should replace the filter/drier also.
I would not recommend rebuilding the compressor yourself. I would also try to have a new not rebuilt compressor installed. The last one I replaced was a napa part. It is only necessary to replace the condenser if it is leaking. $1800.00 sounds about right.Eventually the system will lose its charge at the carbon seal in front of the compressor. If the noise does not bother you,you can buy R-134a and recharge the system your self when it stops working. The bearing will eventually seize stalling the motor.You then turn off the a/c to restart and make it home. Any refrigerant leak leaves a oil stain at that area,so you may see oil around the front of your compressor.
To A/C Compressor Bearing
