competitive driving mode
Old Jul 13, 2011 | 05:44 PM
fastls3's Avatar
fastls3
Default competitive driving mode
So i have a 08 auto and my dad just picked up a 09 auto, there twin cars. his has the competitive driving mode after you hit the trac button twice but mine wont do it. was this a option starting in 09 or is my car being goofy? One of my tire sensors are bad so my light is on for that would that make it not work? Thanks for any help.
Old Jul 13, 2011 | 05:46 PM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
I think they all have it. My 07 has it.
Old Jul 13, 2011 | 05:47 PM
Hrdtop00's Avatar
Hrdtop00
My 06 has it
Old Jul 13, 2011 | 05:52 PM
RicK T's Avatar
RicK T
That's it. The system is designed to not work unless every other related system is functioning properly.......for your protection.
Old Jul 13, 2011 | 05:57 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
That is exactly why it isn't working.
From your owners manual (Section 4-8, page 252 in the PDF version):
If the Tire Pressure Monitor (TPM) system detects a flat
tire and the Driver Information Center (DIC) displays
TIRE FLAT, or if the TPM system is malfunctioning and
the DIC displays SERVICE TIRE MONITOR, the
Active Handling System will be affected as follows:
• The Active Handling System cannot be turned off by
the driver.
• If the Active Handling System is off, it will be turned
on automatically.
• Competitive Driving Mode is unavailable.
• The Active Handling System will feel different in
aiding and maintaining directional control.
Old Jul 13, 2011 | 06:00 PM
BEZ06's Avatar
BEZ06
......One of my tire sensors are bad so my light is on for that would that make it not work? Thanks for any help.
There's your problem!!!
The AH is designed to protect you if you lose pressure in a tire, and even if you have it in Comp or completely off it will turn AH back full on automatically if you're driving down the highway and lose pressure.
When you start the car the AH and TC are full on
After starting, one push of the button turns off TC; AH is still full on
2 quick button pushes turns off TC and puts AH into the Comp mode (AH is still on, but will let the tail end slide around a little more before it kicks in).
Push and hold the button for about 10 seconds and everything will turn off - no TC and no AH at all.
Bob
Old Jul 13, 2011 | 06:03 PM
fastls3's Avatar
fastls3
Thanks guys. It still will let me do traction off. So I guess ill get that sensor fixed and see what happens
Old Jul 13, 2011 | 07:17 PM
06 C6 vert's Avatar
06 C6 vert
C mode is just for the track. You dont want to use it on the street anyway.
C mode slows down throttle response so when you are road racing and hit a bump in a turn the traction will have a more subtle effect and keep you stable.
On the street you want quick throttle response so C mode is not good for the street.
Best set up for the street IMO is traction control off. This is the first setting on the button. This setting leaves the AH on and traction Control off.
If its raining or you have ice you want all nannys on.
Old Jul 13, 2011 | 08:19 PM
Icetech's Avatar
Icetech
it is the sensor.. i just went through that last week on my new gs... unhooked the battery for bout 5 hours to install strereo goodies and when i put it back i thought the tc was broken.. just needed to drive aroudn the block and the computer saw the sensors again and it worked again
Old Jul 13, 2011 | 10:22 PM
kopsis's Avatar
kopsis
Can you share your source for this info? Nothing I've seen published on AH has ever mentioned this. And having driven Sebring - with possibly some of the worst bumps in the worst spots of any track in the US - I don't see how this would be the least bit helpful. Throttle control is the least of your worries on the bump laden corners.
Old Jul 13, 2011 | 10:41 PM
wingbone's Avatar
wingbone
My 05 has it
Old Jul 14, 2011 | 04:08 AM
06 C6 vert's Avatar
06 C6 vert
That's what search is for! The Cow dude has map curves posted, he explains the whole thing also.
Thats why it's sluggish in C mode when not WOT
Put throttle response in the search
To competitive driving mode
