Seat Removal
Old Jul 17, 2011 | 10:06 PM
weathermaker's Avatar
weathermaker
Default Seat Removal
I'm dumb, so bear with me! How do you remove the plastic covers over the front bolts? Do you pry the bottom of the clip, or the riser? Is there a release clip or something holding them? I don't want to break them. Thanks!
Old Jul 17, 2011 | 10:12 PM
thedigitel's Avatar
thedigitel
Phillips head screws, one on each plastic piece. Then push them towards the front of the car, they will come off. Don't pull up on them as you will break a tab under the front.
Old Jul 17, 2011 | 10:15 PM
weathermaker
Thank You! I definitely would have broken it. I have a loose bolt and need to tighten it. Thanks again!
Old Jul 17, 2011 | 10:59 PM
HOXXOH's Avatar
HOXXOH
Mine has the plastic push pins instead of screws on the vertical surface. Pry out the center pin and then the outer one.
Old Jul 17, 2011 | 11:54 PM
Bill Dearborn's Avatar
Bill Dearborn
Both of my C5s had the push pins and my 08Z has them as well.
Bill
Old Jul 18, 2011 | 06:28 AM
weathermaker
Thanks! I'll check for push pins or screws.
Old Jul 18, 2011 | 07:35 AM
speedraider's Avatar
speedraider
same here , my is also an 08. I have never seen screws
To Seat Removal
