Targa Top help
Old Jul 22, 2011 | 01:07 AM
ttazzijr's Avatar
ttazzijr
Default Targa Top help
hey guys, i have a c6 coupe with a targa that i take off very often. However, its becoming a real pain. I always feel really awkward carrying it and i always have trouble getting it in correctly while re-installing it. I was just wondering if anyone had any tips. thanks a lot
Old Jul 22, 2011 | 01:17 AM
mcc978's Avatar
mcc978
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17,’18,’19
Here is a video that shows a good way to remove and reinstall the top:
Old Jul 22, 2011 | 02:07 AM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
Doesn't get any easier than that video shows. Maybe your short? That would make it tougher. Take the top off a lot, do ya? Maybe its time for a vert.
Old Jul 24, 2011 | 03:10 AM
ttazzijr's Avatar
ttazzijr
ya....im a bit shorter and thats probably why. 5'10. As for the vert, i couldnt really justify spending the 6-7K more to get one since the coupe has the targa anyways . Hopefully i will eventually become a pro
Old Jul 24, 2011 | 09:40 AM
mudfish's Avatar
mudfish
That video actually glosses over the one tough part of removing the top. When I take it off I have one hand in front and one in back (just like in the video). If you notice in the video they cut away and when he goes to put the top in the trunk, his hands are at the sides of the top. That's cheating! The only part of removing the top that I find awkward is putting the roof in the trunk with my hands still at the front and back.
Old Jul 24, 2011 | 09:47 AM
R&L's C6's Avatar
R&L's C6
I usually have to rest the top on my shoe to re adjust my grip to the sides.
Old Jul 24, 2011 | 09:48 AM
MARSC6's Avatar
MARSC6
After doing it many times its pretty easy now. The only thing I do different then the video is install it in the trunk standing to the side. I don't change my hand positions .
Old Jul 24, 2011 | 09:51 AM
EDinPA's Avatar
EDinPA
Skip trying to switch hand positions, it's not needed.
Old Jul 24, 2011 | 10:24 AM
mudfish's Avatar
mudfish
Never thought of standing to the side. I'll try that today. I can get it in without adjusting my hands from the rear, but it is awkward.
Old Jul 24, 2011 | 11:09 AM
Thrash's Avatar
Thrash
Why not try a suction-cup handler <CLICK HERE> they're just $13, maybe use 2. I think this would be a great assist ...
Note: They also have a single-cup model ...
Old Jul 24, 2011 | 11:23 AM
boraxman's Avatar
boraxman
Thats pretty much how I do mine and it spends most of the time back there/
Old Jul 24, 2011 | 11:31 AM
ArcticLS3's Avatar
ArcticLS3
I don't switch hand positions either. I just lean over the back end.. pretty easy actually.
Old Jul 24, 2011 | 11:38 AM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
I wish my rear pins went in as easily as it does on the video, when installing it. My 2010 I had was no problem, but on the 2011 I have a real tough time getting those rear pins to seat.
Old Jul 24, 2011 | 11:45 AM
Gman in NC's Avatar
Gman in NC
One key thing here that they don't mention (it shows in the video though) is make sure you do this with the door open. This lets you get a lot closer and have better control of everything. Also a set of garden gloves with those little rubber dots will help. I keep a set in my storage hole incase I have to put the top back on when it's windy.
Old Jul 24, 2011 | 12:01 PM
phileaglesfan's Avatar
phileaglesfan
Not even close to $6k more for a Vert.
Old Jul 24, 2011 | 12:56 PM
Brunotheboxer's Avatar
Brunotheboxer
$5K more.
Old Jul 24, 2011 | 01:21 PM
4thC4at60's Avatar
4thC4at60
ya....im a bit shorter and thats probably why. 5'10. <snip>
I'm an inch shorter than you are and have zero problems - this is my fifth Corvette in the past 20 years. During the spring, fall, and on nice winter days the top comes off....
To Targa Top help
Old Jul 24, 2011 | 07:41 PM
mudfish's Avatar
mudfish
Did the move where you put the top in the trunk while standing at the side of the car. We have a winner! Much easier.
Old Jul 24, 2011 | 07:47 PM
dvilin's Avatar
dvilin
I pretty much do it as in the video, but must admit the first few times it was a bit awkward, specifically when you first lift the roof off, it is a bit heavier than you think. Not much of an issue now, just takes some time to get comfortable with the routine.
Old Jul 24, 2011 | 09:34 PM
choprfgr's Avatar
choprfgr
I put one hand under one on the side - flip it up in the air -
run around to the back - catch it - spin it and drop it in. 1-2-3
