Front crossed flags emblem
Old Jul 22, 2011 | 03:48 PM
beepster's Avatar
beepster
Default Front crossed flags emblem
Does anyone know if the front (or waterfall) emblems are just mounted with adhesive or do they have pins and require drilling?
Old Jul 22, 2011 | 03:52 PM
laconiajack's Avatar
laconiajack
I think the front emblem may be held on with adhesive but is located by pins in recesses in the body.
Old Jul 22, 2011 | 03:58 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
The front is probably the same as in the rear ... It's a plastic emblem with a strong double sided tape / adhesive attaching it. Once removed, you really can't reuse the emblem unless you could scrape off the adhesive and re-apply the double sided adhesive tape.
As Jack mentioned, there are 3 little plastic pins on the emblem that fit holes in the bumper for proper placement.
Old Jul 22, 2011 | 04:21 PM
beepster's Avatar
beepster
Thanx for the replies...I was looking for one to mount on my golf cart
Old Jul 22, 2011 | 04:27 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Don't forget the widebody kit and be sure to Zaino it!
Old Jul 22, 2011 | 04:42 PM
G00SEiv's Avatar
G00SEiv
You could just buy a new one and break the pins off of it, then it could mount anywhere...
Old Jul 22, 2011 | 05:18 PM
JoesC5's Avatar
JoesC5
I purchased a waterfall from RPI designs along with a stock GM emblem that is identical to the nose emblem( believe that is what it is, but not sure. It didn't have any pins, just the tape.
Looking at the nose pieces after they go through the paint booth at Bowling Green, I don't recall seeing any holes for pins. Now, for the rear emblem, I believe I saw some dimples, on the photo of the new blue color that was sprayed on a rear bumper and was shown at the museum when they were showing off the new centennial editions
Old Jul 22, 2011 | 05:25 PM
marathon's Avatar
marathon
St. Jude Donor '09
I replaced front and rear flags on my '05 with the chrome edge ones that came out in '09 and they definitely had pins.
Old Jul 22, 2011 | 06:34 PM
VET4LES's Avatar
VET4LES
I did the same thing.
Old Jul 22, 2011 | 06:47 PM
Don-Vette's Avatar
Don-Vette
I got one on eBay for $19. Files the pins off and used a glue gun to mount it on my cargo divider.
Old Jul 22, 2011 | 07:01 PM
azcanuk's Avatar
azcanuk
There are two pins, double sided sticky tape.. have one sitting here on my desk that was taken off the front nose of my 11 GS when I had a factory painted nose installed..
Two pins..
Two holes..
Double sided sticky tape..
Old Feb 20, 2022 | 01:53 PM
RonAllen1971's Avatar
RonAllen1971
Thanks to all that had good advice and the heads up on Corvette Mods. No sweat off my ***, it was just over $100 on the deal I got so I will power it and hang it in the garage for decoration. I do need to get a new front emblem because the plant did not install it even with the stripes when they did it. On to the next project and enjoying the ole AY C8.
To Front crossed flags emblem
