Griots or pc7424xp
Although its more work, I would use the zaino system on your car. You will cuss and fuss the first time you use it, but over time you will be a happy you did. I don't recall the product they have for removing swirls (help me here guys), but I think its called fusion.
I have a couple of friends that have black c5's with some aged black paint, but it is clear beyond belief.
I wont say anything bad about one product or another, but I will say I have used griots, but not the pc.
Just my 2 cents, but I am as picky (neurotic) about my paint as one could be.
Good luck.
More power, better warranty. Even though it's not a "forced rotation" machine, it's almost impossible to stop pad rotation, even with extremely heavy pressure. This is a sign of a lot of power.
I never use the 7424 anymore, now that I have the Griots.
C6 paint is ROCK-HARD! You should go to Truth in Detailing and search for "Corvette". I have many threads over there on polishing with the Griots and the use of M105/M205 to achieve perfect results.
The above poster is correct. You'll be cussing that rock hard black paint. It will take a lot of time, a lot of pressure, and a lot of practice!!!
Zaino will not remove any scratchs, swirlmarks, etc. Neither will any other sealant. You must get the swirls out first by polishing, then apply your sealant. I would recommend either Zaino or Blackfire Wet Diamond. Both excellent products!
Where are you located?
M105/M205 is a great combo (just did that this weekend on mine) but it took me a while to learn how to use M105 effectively (prime your pads, use very little product, and clean the pads frequently). Used incorrectly, M105 flashes to something that is really hard to wipe off. Be aware that you will get a good bit of dusting with M105. Not as bad as a lot of compounds, but bad enough you'll need a wash step in between unless you do a paint shop level tape off on the glass and trim.
You'll also need the right pads -- something relatively aggressive for the M105 and something quite a bit softer for M205. Have you looked at the Mequiars DA Microfiber Correction System? It's also a two stage (compound/polish) system, but uses MF pads instead of foam. I've heard really good things about it -- both in terms of ease of use and quality of results. If you're just getting started with DA paint correction, you may find this is a more user-friendly option.
No matter the choice do some study to purchase the best polishes, and pads to work within your buffer. Also consider the size of the backing plate and pads. Most will suggest 5.5 inch pads and a 5 inch backing plate with either of the three random orbitals. For normal polishing you will find flat pads and Hydro-tech pads offered most. For heavier polishing you might wanna invest in Surbuf or Megs DA system which use a microfiber type cutting pad. For polishes you will often hear Wolfgang, Megs, and Menzerna offered and all work well on our Vettes.
When your ready, look up your friendly forum supporter Autogeek. Let us earn your business before, during, and after the sale. We also offer a forum as needed to ask questions and get real time answers from individuals using the products and lines your considering. Not just professionals, but weekend hobbist. Car detailing can be fun !
www.autogeek.net
I buy all my detail supplies from Auto Geek, great vendors as well as forum supporters.
I agree, I have both and the Griots is simply the better machine by a long shot. Much more powerful and a much better warranty.
Basically, it describes the best method for getting rotary-like results from a Random Orbital polisher.
It works.... I've been using the method for a couple years and the Vettes I polish look like brand new paint.
I use a rotary- 10x faster, and IMO leaves you with a much better surface to start the "finishing" or jeweling (as some refer to it) process.
In the hands of a noob- a rotary can be instant disaster. But if you can take the time to learn it, 300.00 invested in one is a better use of that money than 300.00 in a Griots- or any PC for that matter.
As far as the OP..the Vettes clear is hard as hell..I find that scratch removal is difficult (and time consuming) with a PC.
I opted for the Griot’s RO. The paint was a bit rough to my standards from the dealer prepping it with a steel wool pad or so it appeared. I gave it a once over with Griot’s Machine Polish #3 which removed all the clear coat scratches (admittedly it takes some work with a Random Obital, but much safer for the novice).
Now I just clay the car occasionally and apply 2 coats of Griot’s Best-of-Show wax with the RO and remove the wax with Griot’s SpeedShine. I’m very satisfied with their products…well, except for their “World’s Finest” spray bottles…had 3 of ‘em crap out on me now.
