Cleaning the Engine
Old Jul 25, 2011 | 01:53 PM
Tonz-A-Fn's Avatar
Tonz-A-Fn
Default Cleaning the Engine
I am getting ready to clean the engine bay and I was wondering if there are components that need to be covered before I proceed.
Please help.
Thank you in advance.
Old Jul 25, 2011 | 02:02 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I generally just cover the alt and fuse box.
Old Jul 25, 2011 | 02:07 PM
Thrash's Avatar
Thrash
Cover the ECS next to the batt, and any open plugs here and there ...
Old Jul 25, 2011 | 02:09 PM
IDSRVIT's Avatar
IDSRVIT
Hose only on a light spray.... my advice would be to NOT use a power washer.
There is too much electronics in there to chance a power washer.
Old Jul 25, 2011 | 02:10 PM
cclive's Avatar
cclive
I spray the rubber with armor all before washing...and definitely no power washer.
Old Jul 25, 2011 | 02:15 PM
carpe dm's Avatar
carpe dm
A better way (unless it is really dirty!) is to wet a towel with detailer, and wipe the compartment down.
Old Jul 25, 2011 | 02:41 PM
IDSRVIT's Avatar
IDSRVIT
Fully agree
Old Jul 25, 2011 | 04:39 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
I use Adams All Purpose cleaner on and then a light rinse (almost mist) with a gardern hose.
Old Jul 25, 2011 | 05:37 PM
Steve Snake Driver's Avatar
Steve Snake Driver
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
A Swifter duster will get out a lot of dirt/dust that would otherwise be unreachable. If you do put water on the engine, make sure it isn't hot.
Old Jul 25, 2011 | 06:18 PM
Guitarstar's Avatar
Guitarstar
No water hose will ever touch my engine, as mentioned prior, wipe down with a damp cloth, I use Griots Speed Shine, then go over the hoses with Turtle Wax tire shine in the green bottle. Perfect.
Old Jul 25, 2011 | 06:28 PM
Bandit1's Avatar
Bandit1
I usually cover the battery, the belt tensioner pulley, the TPS, fuse box, alternator, and the cooling fan motors. Keep the hose sprayer on a fan spray or fine mist.
Old Jul 25, 2011 | 08:26 PM
cclive's Avatar
cclive
Still only one fan and one motor on that fan.
(as it comes from the factory)
To Cleaning the Engine
