C6 Tail light drying?
Old Aug 6, 2011 | 08:16 AM
carl3989's Avatar
carl3989
USN
Default C6 Tail light drying?
Short of buying the Super Blaster + $300 how do you dry the tail lights? No matter how often I try to get into the recess in the bumper the tail lights still have water between them and their socket holes in the bumper. Even tried Bounty "the quicker picker upper".LOL
Old Aug 6, 2011 | 08:18 AM
Eppieguy's Avatar
Eppieguy
Leaf blower. They sell seals for the tailights but never used them so can't tell you if they work or not.
Old Aug 6, 2011 | 08:25 AM
Dino 615's Avatar
Dino 615
I dry mine with a microfiber towel. When I am done, I go to the tail lights and just jam the microfiber in the bottom crease and it soaks up every drop. I just hold the towel there for about 5 seconds per light and it grabs every drop.
Old Aug 6, 2011 | 09:17 AM
designerRob's Avatar
designerRob
It won't be a problem if you get the taillight seals. They prevent the water from gathering in behind the lights. Multiple vedors sell these but I got mine from southercarparts. They are a vendor here. I think they only cost about $20.
Old Aug 6, 2011 | 09:21 AM
NOCRISIS's Avatar
NOCRISIS
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
,,,and the master blaster is a nice touch also,,,,
Old Aug 6, 2011 | 09:23 AM
boraxman's Avatar
boraxman
I have seals but have been too lazy to install em. Air compressor for now.
Old Aug 6, 2011 | 09:43 AM
George Ware's Avatar
George Ware
My problems went away after I started using a leaf blower.
Now the drivers & passengers side mirrors are another story.
George Ware
Old Aug 6, 2011 | 10:11 AM
hanks10GS's Avatar
hanks10GS
George Ware
Plastic bags with rubber bands seem to work well for me on the mirrors.
Old Aug 6, 2011 | 10:27 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
Master Blaster (my personal) favorite or a leaf blower. Use a good safe towel, like a Waffle Weave Microfiber to rewipe area to remove anything left over.
Old Aug 6, 2011 | 12:40 PM
Zoxxo's Avatar
Zoxxo
Ditto. Works for me just fine.
Z//
Old Aug 6, 2011 | 12:46 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
THIS
Old Aug 6, 2011 | 12:47 PM
easyrider13's Avatar
easyrider13
I use a Toro electric leaf blower that I got for about $20 several years ago. It also comes in handy for blowing off sand and leaves from the garage floor.
Old Aug 6, 2011 | 01:38 PM
quicksilver436's Avatar
quicksilver436
Air compressor. Use it on tail lights, seams, around side lights, rear diffuser, tires and wheels, grill area, etc....... even to keep tires properly inflated. Also keeps the wheel barrow tire inflated so my wife can use it for yard work.
Old Aug 6, 2011 | 01:51 PM
coolcat's Avatar
coolcat
I follow the same exact procedure when drying the tailights on my 08 coupe.
I also use a Bounty paper towel to soak up excess water in the side marker lights.
Works like a charm!
Old Aug 6, 2011 | 03:45 PM
rchbn's Avatar
rchbn
I bought seals from a vendor here. They are basically door foam weather stripping (I paid the corvette tax price compared to going to Home Depot and buying a whole role for $4) you take the tail light out and put this foam in to keep water from pooling behind the light. If GM would have put the opening at the bottom of the bumper instead of two spots higher up this problem wouldn't occur. But maybe the engineers looked at this and thought water pooling for hours is better than water running inside the bumper and out the back?
Old Aug 6, 2011 | 03:54 PM
sprtplt's Avatar
sprtplt
Someone needs to invent some special super tiny absorbent booms to lay there and sop up the drips...
Old Aug 6, 2011 | 06:44 PM
JRS 94's Avatar
JRS 94
Shop vac work great
To C6 Tail light drying?
Old Aug 6, 2011 | 08:13 PM
bklyn vette's Avatar
bklyn vette
Old Aug 6, 2011 | 08:18 PM
TMyers's Avatar
TMyers
Get the seals, it makes life so much easier and only takes 30 minutes to install. Others leaf blow, compressed air, etc.
Old Aug 6, 2011 | 08:45 PM
last901's Avatar
last901
Me too...
