tire chatter
Old Aug 6, 2011 | 08:34 AM
vetter61's Avatar
vetter61
Default tire chatter
I have a 2011 GS Coupe that exhibits what I describe as a bumpy feeling in the right tire when I turn a hard left to enter my garage. At first I thought I was rolling over small sticks on my driveway. I used my leaf blower to make sure driveway was absolutely clean.I tryed again but Felt the same bumpy symtom coming from the tire. Anyone else experience this. I plan on seeing what happens if I turn the car a hard right. Wheels are torqued correctly. Car has 2500 miles.
Old Aug 6, 2011 | 08:36 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Normal for the Z06 and Grand Sport. The tires kind of slip on very tight low speed turns in driveways and parking lots. Happens in both directions.
Old Aug 6, 2011 | 08:45 AM
C7Joy's Avatar
C7Joy
My base vert seems to do the same at times in my driveway if I cramp the wheels right to the stops.
Old Aug 6, 2011 | 09:12 AM
Who Needs Turbo's Avatar
Who Needs Turbo
I read on here before that it's due to how wide the tires are.
Old Aug 6, 2011 | 10:24 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Basically, when you are turning at a hard lock (either left or right) the wide width of the tires and camber in combination with the tighter radius of the inside wheel causes a scrubbing of the outer tire as it is trying to keep up with the turn ff the inside wheel. It is basically gaining traction and then losing traction over and over again in the turn.
To tire chatter
