Wheel weights
Old Aug 6, 2011 | 02:04 PM
SuperSonic's Avatar
SuperSonic
Default Wheel weights
Found some wheel weight in driveway that have come lose abd fell off. Any proven method on how to secure these better ? What have you found that works well ? Thanks
Old Aug 6, 2011 | 02:40 PM
Kenny94945's Avatar
Kenny94945
Clip on or Tape On?
Tape on .... clean the rim with contact cleaner before applying the weight.
Clip on ... Quality control. Inspect the clip. Different brands equal different shapes and quality. Maybe give it a little extra tap to make sure it seats fully.
Old Aug 6, 2011 | 03:08 PM
Rock-it Man's Avatar
Rock-it Man
It's all about surface prep:
http://multimedia.3m.com/mws/mediawe...22GCIfrCffffE-
Who balanced your wheels? They owe you a do-over using the correct solvent.
Old Aug 6, 2011 | 04:16 PM
RedVette84's Avatar
RedVette84
Old Aug 6, 2011 | 04:37 PM
SuperSonic's Avatar
SuperSonic
Thanks, It was done at the factory. 2011 with less than 2,000 miles.....Back to dealer, I guess........
Old Aug 6, 2011 | 04:38 PM
SuperSonic's Avatar
SuperSonic
Originally Posted by Kenny94945
Clip on or Tape On?
Tape
Old Aug 6, 2011 | 04:40 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Actually it wasn't but you should let them know. The wheels and tires arrive mounted, inflated and balanced for assembly on to the Corvette but they should not be falling off. Consider sending a note to the engineers at the assembly plant so they can take your information.
Use the following link:
http://bowlinggreenassemblyplant.com/
Click on the yellow "Owner Feedback" button at the bottom of the page.
To Wheel weights
